[Z06] To Align or not to align
Old Mar 16, 2006 | 09:48 PM
JADVette94's Avatar
JADVette94
Default To Align or not to align
I have just over 10,000 miles on my 04 Z and the inside edges of the front tires are almost worn out. I made an alignment appointment for Saturday at a local tire shop, but in reading some of the threads on here, it sounds like the inside front tire wear may actually be normal. I have one track day and about 7 autocrosses on them and the stock alignment from the factory. Should I get it aligned, or is the tire wear normal? The rear tires are fine. Thanks.
Old Mar 16, 2006 | 09:57 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi JADVette94 -
I have a 2002 Z06 and a 1999 coupe -
Neither of them wear the tires on the fronts abnormally.
I would have it aligned.
The rears on our cars seem to wear out very quickly, though.
best regards -
mqqn
Old Mar 16, 2006 | 10:04 PM
H82GOSLW's Avatar
H82GOSLW
Originally Posted by mqqn
Hi JADVette94 -
best regards -
mqqn
Old Mar 16, 2006 | 10:44 PM
SoulDad570's Avatar
SoulDad570
It's hard to say without seeing the tires. But the Z06 stock alignment does result in faster wear on the insides of the front tires. Not so much that the middle of the tire has lots of tread while the insides are corded. But the uneven wear is noticeable.
It's a good idea to align periodically anyway though.
Ciao,
Rick
Old Mar 16, 2006 | 10:48 PM
Andy64's Avatar
Andy64
Here is a previous thread on the same topic. Hopefully you will find some good, helpful info in it.
http://forums.corvetteforum.com/show...nt&forum_id=49
Old Mar 17, 2006 | 12:08 PM
tramminc's Avatar
tramminc
did my 03 z06 today and what a big differents
Old Mar 17, 2006 | 04:32 PM
Mike04Z06's Avatar
Mike04Z06
I have the opposite problem, the OUTSIDES of my front tires are abnormally worn at 11,800 miles...
However this is probably due to the fact that I take every corner like I'm on a racetrack! Well not every corner but my normal commute involves a totally kickass onramp which has 2 sharp rights and a sharp left that I can take at 90-100mph and I also hit a few other really nice curves both directions.
I can definitely see having to replace my tires at around 16,000 miles...just a shame that the middle/insides will be fine and the outsides will be worn through the tread
Old Mar 17, 2006 | 04:51 PM
Miguels's Avatar
Miguels
[QUOTE=Mike04Z06] involves a totally kickass onramp which has 2 sharp rights and a sharp left that I can take at 90-100mph and I also hit a few other really nice curves both directions.
QUOTE]
right.
Old Mar 17, 2006 | 05:14 PM
F1_SS's Avatar
F1_SS
Can i get a life insurance policy in your name and me be the beneficiary?
Old Mar 18, 2006 | 03:07 PM
Cruncher's Avatar
Cruncher
On my 03 Z06, I had the problem of the inside edges wearing. The OEM tires lasted 13K miles. I replaced them with PS2s...I doubt that these will last 13K miles based on 6K miles.
To To Align or not to align
