door speaker removal ?
Old Mar 19, 2006 | 03:02 PM
maddman's Avatar
maddman
Default door speaker removal ?
What is thw best way to remove the door speakers in a 99 coupe.Chacked the audio section allready thanks
Old Mar 19, 2006 | 03:11 PM
shakainc's Avatar
shakainc
Remove door panels. Unscrew speakers. Ha, Ha. What are you trying to do? Are you just wanting to change speakers?
Old Mar 19, 2006 | 03:27 PM
maddman's Avatar
maddman
full on eclipse system. best way to remove door panels
Old Mar 19, 2006 | 03:47 PM
shakainc's Avatar
shakainc
Door panel has small push-in plastic screw pins. Didn't know what else to call them. The best way is to get a door pin puller. It's like a screw driver with a fork at the end. If you don't have one you'll risk breaking the part of the door panel that holds the pins. There is also screws behind the door handle. Remove the little covers behind the door handle and you'll see them. Once they're all loose you can slide the door panel up and off. It's been a while since I've done this. If I'm missing something I hope someone will speak up.
To door speaker removal ?
