Remote Starter
Old Mar 20, 2006 | 03:18 PM
jstaples33's Avatar
jstaples33
Default Remote Starter
Does anyone here have a remote starter & if so any help on installing one,I am also looking for instructions for lowering a 98 on the stock bolts.Thanks in advance...
Old Mar 20, 2006 | 03:57 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
DEI/Viper makes a good remote starter, you'll need the VATS by-pass. I had a local shop do it for $300
Good luck
Old Mar 20, 2006 | 04:06 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Lowering How-to
https://www.corvetteforum.com/techti...D=27&TopicID=1
Old Mar 20, 2006 | 04:16 PM
JTS97Z28's Avatar
JTS97Z28
I am a certified installer and have done countless numbers of remote start installations. I mainly install the Viper DEI units which are VERY good quality systems. However unless you know exactly what you are doing I would highly recommend getting it done by a professional. You will be tapping into (soldering) critical vehicle wires such as all of the heavy gauge ignition wires, factory alarm disarm/arm, lock and unlock, parking lights, brake signal, tach and many more. Not to mention most newer cars you will need relays, sometimes diodes and resistors, and for sure the VATS bypass for the Corvette.
The Viper 160xv is the most popular unit and includes 2 remotes, and can completely replace your factory remote for power locks and trunk pop. This unit goes for around $200, then you need the GM VATS bypass which is around $55 then labor costs if you decide to have it done somewhere.
If you are serious about doing it yourself PM me and I can get you the tech sheets for the C5 Corvette that we use at work which gives you all the wiring info you need for the DEI viper install.
JT
Old Mar 20, 2006 | 08:18 PM
Mike04's Avatar
Mike04
Originally Posted by EnglandGreen
Does this seem out of place....
Old Mar 20, 2006 | 08:35 PM
0EG@EnglandGreen
Supporting Tuner
With all due respect - reading is essential.
Old Mar 20, 2006 | 09:11 PM
Mike Mercury's Avatar
Mike Mercury
To Remote Starter
