[Z06] 600rwhp Enough for 9s?
Old Mar 20, 2006 | 04:03 PM
TravG's Avatar
TravG
Default 600rwhp Enough for 9s?
Z06 heads/cam 450rwhp on motor 615rwhp on a 175 shot.
Stock trans w/ hurst, spec 5 clutch
Stock rear( )
I went 10.90s back when I had just the 100 jets in and longtubes on MT drag radials...
Can I hit a 9 on the big jets? Do I need ET Streets? Am I gonna grenade something?
Anyone recommend a strong daily driver clutch? This is my 3rd Spec Lvl 5... It grips great but wears out super quickly.
Old Mar 20, 2006 | 04:46 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
For that kind of HP to get a car in the 9s, you really need a sorted out suspension as it will take 60' times in the 1.30s (or better) unless you have BIG HP. And a relatively stock Z06 isn't considered light weight in drag racing terms.
As a point of reference, a friend of mine has a 3100lb S10 (yes truck) wiht a 406 that makes 850HP CHP. He has gone 1.28 60' with big Quick Time Pros and that got him very deep mid-9s.
Old Mar 20, 2006 | 04:48 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I'd start saving for a DTE dif and dif brace setup. Do you do the clutch swaps yourself? Other wise you've spend a mint in labor.
Old Mar 20, 2006 | 04:50 PM
TravG's Avatar
TravG
Ok so I went 10.90 with ~450rwhp and Drag Radials, but 9.90s arent possible with ET Street or full on slicks and 615rwhp? What do you think I'd run? Thats 165 more rwhp and even more rwtq.
Old Mar 20, 2006 | 04:53 PM
TravG's Avatar
TravG
I have the brace but other than that its all stock. IE Gears, shafts everything. I have a good friend that works on C5s.
Old Mar 20, 2006 | 05:11 PM
F1_SS's Avatar
F1_SS
How is the motor even alive at 615rwhp unless you are forged?
My understanding is basically you need 100hp to cut 1 sec off. This way sway a little but its pretty much true (give or take).
Old Mar 20, 2006 | 05:13 PM
TravG's Avatar
TravG
I just run 103 when I spray. Head/cam + 150 shot cars are very common... Don't see what the big deal is.
I think the car would go low 10s but not 9s I think I'd need around 650rwhp to get in the 9s.
Old Mar 20, 2006 | 05:23 PM
F1_SS's Avatar
F1_SS
I have always heard that 550rwhp was about the limit of stock bottom end ls1-6's. Im searching for 10.99999 once i get the MS3 cam installed + N2o
Old Mar 20, 2006 | 07:59 PM
OneBadCEZo6's Avatar
OneBadCEZo6
So, You ran a 10.90 with 450rwhp and 100shot? If I hear this correct It took you 450rwhp And 100shot to run a 10.90?? You should have been running 10.80's On motor with a 1.40's 60ft and with a 100 shot of gas 10.09 and 150shot 9.90's
I think some of it might be in your driven skills... I went 7.54@99.8 1/8th On stock tires and It was wheel hopping like a crack ***** that just won the lotto
Old Mar 20, 2006 | 09:53 PM
TravG's Avatar
TravG
Car made ~350 on motor and 450 on the 100 shot. So I ran 10.90 with 450rwhp. You were NOT reading correctly.
The car dyno'd a little low for a stock Z06. Not sure what it was making when I went the 10.90 but it just had a halltech stinger and longtubes and the 100 shot. NOTHING else. On BFG DRs. 10.90@128(not sure on the mph I think it was 128 though)
Old Mar 20, 2006 | 10:05 PM
robz's Avatar
robz
Keep in mind it's not only the hp. You have to shift the crap out of it and hold traction to run 9's in a stick. Not too many stick cars run 9's period especially with 346.
Also, it takes much more hp to go from 10.99-9.99 than it does to go from say 11.99-10.99. Most people overlook this fact. Plus you have to factor in aerodynamics and traction.
In perfect conditions and the great driving I think 100 shot on a nicely setup H/C car can maybe sqeak out a 9.99.(but the car might have to be setup with nos in mind). I've seen auto with 150 shot run9.9x's but they were stroked.(402,418,427)
My buddys auto 427 c5 ran 10.61 na and 9.85 with a 200shot on the same day. It's just tough to run nines period. Also, different cams respond very differently to nitrous and then you have the gearing issue. If I was to put a 100 shot on my car I would slamm the limiter in 4th before the traps. Alot to think about.
Old Mar 20, 2006 | 10:30 PM
TravG's Avatar
TravG
Good points.
Heres my thinking. I went from 11.90 to 10.90 by adding the 100 shot and changing from stock tires to drag radials.. so now I'll be adding 165 more RWHP(Heads/cam/175 jet instead of 100) and changing to ET Streets/Drags.
Old Mar 20, 2006 | 10:38 PM
korvetkeith's Avatar
korvetkeith
It's deffinately possible. When does your car run out of gear in 4th? A 6 speed is gonna need a lot of trap speed to get into the 9's, like 140+. Good Luck.
Old Mar 21, 2006 | 06:09 AM
LT-4 CE's Avatar
LT-4 CE
There is a concept of diminishing returns in drag racing. As a relatively stock car, a 100 shot of juice will have huge gains. As you start searching for 9s, it takes more than HP. Drive line efficiency is key as is a serious 60' time. There are cars on here running 9s without 1.3X 60' times, but they are making huge power. For you to get 615RWHP in the 9s, I really think you'll need front and rear shock and plenty of track time to dial in the settings, you'll be very much at the limit of the rear end - especially if you hit the spray off the line (which I think you'd need to do to go 9s).
Don't get me wrong, yor car sounds very impressive, but it takes more than HP to get a car in the 9s. The combination must be very well sorted out (HP, trans, gears, tires, suspension, and driver skill are a few).
Old Mar 21, 2006 | 08:19 AM
robz's Avatar
robz
That's what I'm saying. I like your thinking though. Give it a try. I've thought about trying a 100 shot to see what would happen, but would have to change gears.
Old Mar 21, 2006 | 04:59 PM
OneBadCEZo6
Sorry man about me miss understanding.. You Hell thats smoken with a 100shot
Old Mar 21, 2006 | 07:24 PM
Zrod's Avatar
Zrod
I'm not sure if this is real world relevant, but my ET caluclator says:
vehicle wt at 3350 (3100 lb. car, 250 lb. for driver and gas)
rwhp at 674
ET is 9.935
MPH is 137.183
hope that helps!
Old Mar 21, 2006 | 07:33 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Maybe it is just us, but we have produced a handfull of nine sec cars now, and they all took waaaaay over 600rwhp to get them there. But like I said, maybe thats just us. Good luck in your quest for nines.
To 600rwhp Enough for 9s?
