E-Brake fixed, Check.
Old Mar 20, 2006 | 07:57 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Default E-Brake fixed, Check.
Just going thru and trying to knock off a few nagging things before the real driving season starts. As many know the emergency brake on our cars is well, marginal at best. It can be fixed and it's not too bad of a job. The worst part of course is getting the bolts out of the caliper bracket. These are 13/16 with loc-tite torqued to 125 ft./lbs and a bear to budge. Once you get these off, the rest of the job goes by in about 10-15 minutes per wheel. I found my brake out about 20 clicks per wheel. When all was said and done the e-brake engages firmly at about half way up and when engaged the brake will now hold back the car in first gear with a little throttle applied. If you're on the fence about this one and have a little mechanical ability, go for it. You'll be thrilled with the results.
Paul
Old Mar 20, 2006 | 08:07 PM
mredden05's Avatar
mredden05
You can keep it in adjustment by going backwards (down a slight hill works best) and pulling / releasing the e-brake handle several times. Try not to exceed 50 degrees with the handle, or don't fully engage the e-brake. Two or three passes with five or six good pulls (18 total pulls) works great. I do this about once or twice a month to keep from pulling the wheels again.
Old Mar 20, 2006 | 08:14 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Congrats on the fix. I need to do the same!
Old Mar 20, 2006 | 08:43 PM
Jims99frc's Avatar
Jims99frc
Talon 90 , now go try it on the boat ramp of Long pond !
I did mine when I changed rotors , big difference.
Old Mar 20, 2006 | 08:46 PM
talon90's Avatar
talon90
NCM Ambassador
So, you know the area do you. I'll give it a try.
Paul
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
Very common. On my '98, I found the shoe retainer spring was sprung.
My Z is due for a few clicks also...
Old Mar 20, 2006 | 08:53 PM
Jims99frc's Avatar
Jims99frc
Bridgewater ,I use the Nip boat ramp !
JIm
Old Mar 20, 2006 | 08:58 PM
talon90's Avatar
talon90
NCM Ambassador
JIm
Jim
Paul
Old Mar 31, 2006 | 07:34 PM
PJSALERNO's Avatar
PJSALERNO
Stealer wants $400 to fix mine. I get nothing when I apply e-brake. Can you please post the fix procedure, please. Thanks.....
Old Mar 31, 2006 | 08:21 PM
RonJ's Avatar
RonJ
This old wives tale keeps surfacing. Pulling the hand brake while backing up will do squat for you.
There is no self adjusting feature in the parking brake wheel mechanism!!!
RonJ ...
Old Mar 31, 2006 | 08:59 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
This is not true.... sorry you know not what you speak...
that procedure only works for taking slack out of the cable. it does nothing to adjust the engagement of the shoes to rotor.. If the cable has some slack its is only because someone was pulling up too hard on the lever with the shoes fully engaged.. this would never happen because if you pull up on the lever to engage the shoes you would pull it up to vertical and the shoes still wouldn't engage...
Once you take the slack out of the cable you should never have to do it again... there are two separate issues the cable slack and the shoe to rotor adjustment... most ebrakes are around 30 to 40 clicks out...
Mine was 43 clicks out and my ebrake engagement is exactly at 45 degrees from straight up... my ebrake is fully disengaged at 30 degrees...Talon you probably could have gone 5 more clicks...when I teach this adjustment I tell everyone to put the rotor back on with the shoes adjusted as far out as possible and still be able to force the rotors on my hand... once the rotor sits on the backing plate and hub boss the rotor diameter get slightly bigger..
Talon you should never have to adjust this again..
I did mine right from the factory and that was 6 years ago, and its been fine ever since with 6o,000 miles on it
MY original tech tip eluded to a self asjusting mechanism, which there is but only in taking out the cable slack..I have tried several times to edit that tech tip or have it removed but with no success, Ive even had the aDMINISTRATION SAY THEY WOULD HANDLE IT BUT TO NO AVAIL AND i HAVE BEEN TRYING TO FIX THIS FOR THREE YEARS.
Old Apr 1, 2006 | 01:26 AM
nprsuit's Avatar
nprsuit
Evil Twin-So the e brake is NOT self adjusting? I ask cause just this last week I was at the dealership and complained to the tech about the ebrake not engaging until handle is pull all the way up, and even then if I am on a steep enough incline the car wants to move. He tells me there is NO adjustment, it is self adjusting. When I go back I want to know what I am talking about. Thanks
Old Apr 1, 2006 | 08:49 AM
rws.1's Avatar
rws.1
here's the link to E-T's tech tip on adjusting the parking brake. I did it this winter
https://www.corvetteforum.com/techti...=158&TopicID=1
Old Apr 26, 2006 | 09:57 AM
cazvette's Avatar
cazvette
Paul
Thank you for the insight, I'll have to try and adjust my brake this weekend.
Old Apr 26, 2006 | 11:14 AM
Evil-Twin's Avatar
Evil-Twin
When my car had 1000 miles on it, I adjusted the interface between the shoes and the drum... it was out 43 clicks... I did that one time 6 years ago and have never had an issue.. the Ebake handle is tight at 45 degrees when fully locked up...and fully disengages at 30 degrees.
I could use my ebrake to bring me to a stop from 60 mph.
adjusting the cable slick should be done no more than once a year... slow backward movement and five quick pull ups stopping the car. I have never adjusted my cable.
Old Apr 26, 2006 | 11:22 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Thanks .....great instruction as always.
Old Apr 26, 2006 | 01:05 PM
Glad you got it adjusted. Sure is comforting to know that when you park on a hill and set the e-brake, that the car doesn't just start rolling away.
Old Apr 26, 2006 | 01:43 PM
Rebe's Avatar
Rebe
4th Gear
Having been a mechanic for many years, its good to see someone knows what they are talking about.
To E-Brake fixed, Check.
