Does this look lowered?
Old Mar 22, 2006 | 06:21 AM
It looks like it could be slightly lowered, especially in the front, but hard to tell from the angle of the pic. Mine is at stock height and it measures about 4.5" from the ground to the bottom of the air dam. I have the Rhino Ramps too and they will make contact with the air dam before they contact the tire.
Old Mar 22, 2006 | 06:22 AM
Rhode Warrior's Avatar
Rhode Warrior
yes
Old Mar 22, 2006 | 06:27 AM
spdislife's Avatar
spdislife
Hard to tell. Did you check the bolts in the back? If only a couple of threads are showing, then it's been.
Old Mar 22, 2006 | 03:36 PM
shakainc's Avatar
shakainc
Wow. 4.5". That made me think, so I went out and measured mine. Lowered on stock bolts it's 2" from the ground.
Old Mar 23, 2006 | 03:01 AM
striper's Avatar
striper
Definetely not lowered, too much air between the top of the tire and the wheel well.
