3:15 rear
Old Mar 22, 2006 | 07:44 PM
VETGASM58's Avatar
VETGASM58
Default 3:15 rear
Ok I am a bit stupid when it comes to this tech. stuff someone please enlighten me as to the differences in the 2:72 to 3:15 and so on up to 3:42 and so on
Old Mar 22, 2006 | 07:50 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
2.73 is standard with an A/T and the 3.15 is the optional performance upgrade. All manual's came with 3.42's
Bigger rear end means faster acceleration / seat of your pants take-off.
Smaller rear end means higher top speed and better gas mileage.
Old Mar 22, 2006 | 08:26 PM
SirCoryM's Avatar
SirCoryM
on the A4, with everything else considered constant, what is a reasonable guess for the 1/4 mile difference between 2.73s and 3.15s?
Old Mar 22, 2006 | 08:49 PM
Oldad's Avatar
Oldad
CI 6-7-8-9 Veteran
St. Jude Donor '07
Let me add that the housings are different (2.73 vs the rest.)
So if you have a 2.73 and want to change I say go with 3.42.
Just my$.02
Old Mar 22, 2006 | 09:35 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
Depends on the driver, really nothing big, IMHO
Old Mar 22, 2006 | 09:42 PM
doje's Avatar
doje
You can probably pick up about .15 (1 to 2 tenths). Driver is not so important with an automatic (in Drive) other than cutting a good light.
Old Mar 22, 2006 | 09:44 PM
tiojames's Avatar
tiojames
Default rear ends
The numbers are the ratios of the number of times the driveshaft turns for one revolution of the axle. So a 3:15 would spin the axle one time for every 3.15 turns of the driveshaft. A 4:10 would turn the axle one time for every 4.1 times the driveshaft turns. The higher numbers give you more power, less MPH.
To 3:15 rear
