Outside Air Temperature Sensor (REPOST)
Old Mar 22, 2006 | 08:37 PM
77BlueL82's Avatar
77BlueL82
Default Outside Air Temperature Sensor (REPOST)
Can anyone help me find the OATS? It is suppose to be on the radiator support.
I have to replace it because my digital heat isn't working properly.
Thanks in advance.
Old Mar 22, 2006 | 08:40 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
Can't tell you where it is any better that you describe, but I did find out I had to disconnect the battery for a bit in order for it to reset. I changed it out once because it still kept reading wrong. Then I just decided to try a "reboot" (disconnect battery) and the new one started working.
There may be a better way, but passing along my experience
Old Mar 22, 2006 | 09:00 PM
Anthony01's Avatar
Anthony01
Thanks in advance.
Passenger side, at the bottom
Old Mar 22, 2006 | 09:12 PM
ZOOOM's Avatar
ZOOOM
I thought I read that on the '00.... it was in the right front bumper...
ZOOOM
Old Mar 22, 2006 | 10:10 PM
77BlueL82's Avatar
77BlueL82
Default Sensor
I just looked. I have a connector in the place where your's is. Can't find the sensor.
Old Mar 22, 2006 | 10:18 PM
77BlueL82's Avatar
77BlueL82
Default Found it!!!
I was looking in the wrong place.
Old Mar 23, 2006 | 07:08 AM
Glad you found it. Not hard to overlook it.
Old Mar 23, 2006 | 07:23 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
So was it where it was supposed to be or in a different place?
Old Mar 23, 2006 | 05:32 PM
77BlueL82's Avatar
77BlueL82
Default Same place
Right where his photo had it
Old Mar 23, 2006 | 05:52 PM
M_T_0's Avatar
M_T_0
if you crawl under the car you can see the end sticking out into the air intake for the radiator.
More Than Zero
To Outside Air Temperature Sensor (REPOST)
