help getting my knob off...err....
Old Mar 26, 2006 | 02:55 AM
scott_fx's Avatar
scott_fx
Default help getting my **** off...err....
i purchased a b&m short throw shifter but for the life of me i cant get my shift **** off. it's an aftermarket aluminum **** and i think it's just a screw on. could the metal have shrunk due to heat? is there some trick i dont know about? the thing is LOCKED on there. i dont want to use channel locks becuase i'm afraid of marring the surface from the pressure i'd need to lock onto it.
anyone have advice/tips?
tia,
Scott
Old Mar 26, 2006 | 03:25 AM
PHPD7102's Avatar
PHPD7102
St. Jude Donor '14-'15-'16
My buddy had the same problem, after alot of screwing a round he found that the aluminum **** did indeed have a top section that came off. After that it was justa matter of removing the little key and unscrewing it.
Check close to make sure your **** isnt really 2 pieces. If not one of those thing rubber things you use to open jars wrapped arounf the **** then the vice grips on top of that should work.
Old Mar 26, 2006 | 06:00 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Some of those ***** would have a small set screw that tightens on the threads of the shifter shaft.
Old Mar 26, 2006 | 08:13 AM
Hopefully it wasn't put on with Loctite on the threads. Good luck getting it off.
Old Mar 26, 2006 | 08:31 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Do you have any pics of the **** you have?
Threading aluminum onto steel can cause corrosion due to the dissimilar metals reacting. As a rule of thumb, always use anti-sieze compound when mixing the 2 metals. Same goes for engine bolts, sparkplugs, suspension bolts, etc.
If the shifter has been on a long time, this may be your problem, and if so, it might take a LOT of force to break it loose.
Before attacking it with the channellocks, get yourself a rubber strap wrench....these are made for removing/installing chrome and polished pipes on decorative plumbing fixtures. They are very inexpensive and look like this:
To help getting my knob off...err....
