Painting Rear Which Color Code Black?
Old Mar 26, 2006 | 11:25 AM
IDM's Avatar
IDM
Default Painting Rear Which Color Code Black?
What do you guys tell the body shop when having the piece over the exhaust on the rear bumper painted. I was thinking a gloss black would match the gloss of the paint but then I was told that would look fake and I agreed. So do I just tell the shop a flat black or is there a color code I should mention? My car is artic white.
Thanks!
Old Mar 26, 2006 | 11:30 AM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
I believe that the C5 code for black is 41.
Yes, just checked it out. Go here to see for yourself. Zuti
Color Codes
Old Mar 26, 2006 | 11:58 AM
J Z06's Avatar
J Z06
Instead of painting, you could go to this site:
http://www.pfyc.com/store/merchant.m...ory_Code=VTEXT
Old Mar 26, 2006 | 12:03 PM
IDM's Avatar
IDM
Wow I didn't know that existed. However, my bill is going to be 200 total with painting and buffing out the rear and I'd rather not do all the work of installing that rear sticker and messing it up a little or having it peel off later.
Old Mar 26, 2006 | 02:25 PM
IDM's Avatar
IDM
nobody has had the rear bumper painted above the exhaust : ) ?
Old Mar 26, 2006 | 02:38 PM
edensknight's Avatar
edensknight
I had mine painted glossy black over four years ago when it was not quite the interesting trend it is now. And, I decided to opt for the glossy black, instead of a "flat black", not only to match the clear coated finish that is already on the car, BUT, also for a longer wearing and protected finish that yields a deeper, and, more even color. IMHO: The "flat black" had to much of a faded appearance to me. Regardless, this paint scheme to the C5 azz, be it just around the exhaust accent panel, OR, having the whole rear end painted, is really very striking.
Old Mar 26, 2006 | 04:18 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I agree with my friend Eden - I would paint the panel gloss black and clear just like they would have from the factory. It will look much more finished that way.
If you want some actual paint codes - this site might be of some use....
http://www.corvettepaintcodes.com/
Old Mar 26, 2006 | 10:19 PM
IDM's Avatar
IDM
great guys thanks
Can anyone else help me decide please. I just think the gloss black will make it look fake and the flat black will make it look like a rubber trim piece.
Old Mar 26, 2006 | 11:14 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
Default Gloss all the way!!
The paint code you want is 8555
It is the same color I used to match my wing on my 98
Old Mar 27, 2006 | 03:38 AM
EBZ0602's Avatar
EBZ0602
2015 C5 of the Year Finalist
St. Jude Donor '05-'10
IDM,
I think that I would go with a satin black, it is between the gloss and flat, in that it has a shine but is not glossy
and if I'm not mistaken it is the color on the back of the C-5R Corvettes
EBZ0602
Old Mar 27, 2006 | 07:01 AM
Cajun99's Avatar
Cajun99
Since you're looking for opinions I definitely wouldn't use gloss or flat black on Arctic White....it looks like chit. This white is too darn bright in sunlight and gloss black is too reflective for it. The flat black isn't reflective enough. Colors like Torch Red, Electron Blue, Spiral Gray, Mil Yellow are good candidates for gloss black though.
I had mine done in what the poster above mentioned in semi-gloss aka satin black. Don't really need a color code since you don't have to mach the black to anything so I wouldn't worry about that. Your paint guy will know what to do if he's any good. The satin looks pretty good with the white in sunlight.
Mine was painted a few years ago and still looks like it was done yesterday....even after being in the intense sunlight and heat down here.
I think it looks pretty good on the white because optically it narrows the height of the rear end but also makes the rear look wider. Does a good job of accentuating your exhaust system by separating it from the bright white. This white is a tough color to work with because it's so bright.
Good luck with your choice
To Painting Rear Which Color Code Black?
