Which rotors?
Thanks!
Chris
how much money do you have for this project?
There are track rotors , then there are bling rotors.
Track rotors will stop a C5 in everyday driving conditions just like factory rotors.
Track rotors are cheap and are considered throw aways... quality is similar to stock rotors.
Bling rotors are as good as stock rotors for street applicarions... but they look good doing it
Bling rotors have no place on the track, except 1/4 event.
Bling rotors vary in cost from 170 dollars for four to 1200 dollars for four... of course you can find extreme rotors at 3000 to five thousand dollars too.
Brembo Wagner, Bendix,Raybestos most of the cheap bling rotors on Ebay all are made in Canada at the same factory...but they are made to specific specs of the dealer...Some buy rotor blanks from Canada, and do post process in house...
Baers are made in Australia and processed here.
I have 60,000 miles on my Baer Eradispeed 2 piece rotors and they look as good as the day I bought them.
Thanks!
Had mine for a year now no problems.The Best of Corvette for Corvette Enthusiasts
CLICK THIS LINK
CLICK THIS LINK
CLICK THIS LINK
now here is a guy who really has no clue...none ... Nada...
When Newbies come here and ask for information, most think that everyone who posts advice is an authority...
Your post to this tread, left alone, would conclude that the newbies who were going to race their cars, and on your advice, would go out and spend hundreds of dollars on drilled an slotted rotors because that was the advice given on the great Corvette forum... So on your recommendation they would spend their hard earned money on drilled and slotted rotors that will fail in a few hundred miles on the track, possibly cause them physical harm, and find that because of your recommendation , the corvette forum sucks and people do not know what they are doing there.So unless you have first hand knowledge, or are an automotive engineer, or a brake and rotor specialist... I would suggest that you not give out information that is so wrong and so 180 degrees from the truth...
People pm me all the time about posts like yours, that are typically so far from the Truth
I usually get a topic line in PM Like "ET I trust your advice.."
Most people who track their car are using the cheapest rotors they can buy...they all indeed stop the car. NAPA 25 dollar rotors are the choice of many... you can sometimes get two track events from a set..they are not drilled or slotted,with the exception of very space aged rotors in the 4 to 5000 dollar range and are carbon fiber rotors
Drilled and slotted rotors have built in internal stress because of the changes in the surface of the fire path... holes create differences in these stresses, as the rotors heat up these differences heat up differently because the internal stress is not uniform, especially around the holes.. as the molecules around the holes speed up they expand under heat at different rates than the rest of the rotor surface. When The area around the holes heat up at a different rate up they expand ,, when they expand at different rates they crack because the hole will heat up quicker than the rest of the rotor,
Here is a typical example of the hot spots around a hole.
This information is brought to you by a guy who is an ***...
An *** who has to defuse input from people who do not know what they are talking about on a daily basis. Half of my 20 to 50 Pm's a day are because of post like this.
With all My Love
Bill aka ***
