[Z06] Engine temp vs. E.T. and MPH?????
Old Mar 27, 2006 | 08:26 AM
DE Z06's Avatar
DE Z06
7th Gear
Default Engine temp vs. E.T. and MPH?????
Got a drag racing question here maybe someone can answer.
Does the 02-03 Z06 run better when the engine is cooler? Would it be of benefit to go to a 180 or even a 160 stat with a programmer to turn the fans on sooner? I think ranger said it was best to run the car at 190 coolant temp.
Anybody have any good data on a car running faster with lower coolant temp not just lower ambient temp?
Thanks...
Old Mar 27, 2006 | 09:09 AM
Ranger's Avatar
Ranger
With stock PCM, the car runs produces best power at 190-194 degree.
Turning on the high-speed fans using a switch will permit hot-lapping a few back-to-back passes before the clutch becomes heat-soaked.
If you want hard data, good luck. Hardly anyone on this board seems to keep a detailed drag log. I do, but once I figured out the optimal temp for my stock Z06, I no long felt it necessary to experiment with higher or lower water temps at the line.
Some folks (often those with prior C4 experience) state their cars run best at low water temps. Neither my 01 or 02 did. And I tested that with dialed-in driving.
Ranger
Old Mar 27, 2006 | 09:12 AM
DE Z06's Avatar
DE Z06
7th Gear
Thanks Ranger, I hear ya but it can't hurt to ask
Old Mar 27, 2006 | 09:24 AM
Ranger's Avatar
Ranger
Simple test.
(1) get your driving dialed-in, e.g. consistent.
(2) run two passes with a water temp at the line of 155. Then two at 165; then two at 175. Then two at 185. Then two at 195. Make the shifts at same rpm and same strength each pass.
Average the the trap speeds for each temp. See which temp produces the best trap.
Most testimonials are anecdotal based on a couple passes with undialed driving.
For an alternate view, try PMing "Power Shifter." He favors a lower temp. But I believe that his times might have matched mine, except for his low-temp error.
Ranger
Old Mar 28, 2006 | 12:39 AM
sqeznbi's Avatar
sqeznbi
As the late great smokey yunick said "heat makes horespower".
Old Mar 28, 2006 | 06:46 AM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Ranger
Ranger, my tuner expressed similar sentiment - stating it may not be necessary to lower the t-stat in my '02 Z. He feels bumping the fans down a bit may be enough - working off of your 190-194 range.
I have struggled with weather to put a 160 in mine since I got it, but am going to go with just the fan change for now (I think) and see how it goes.
WHen I had my LT-4, it did benefit from a 160 stat and fan reprogram. It was worth nearly a .1 and 1 MPH - or it seemed.
I just can't get over what I learned when I bracket raced in my old Nova. It seemed like every 406 I built ran best between 160-170 - and that is with well over 5,000 runs documented and noted. Car just seemed to fall off once the car got hotter than that. At least I knew to dial up a couple hundreths.
To Engine temp vs. E.T. and MPH?????
