Radar detector installation
Old Mar 27, 2006 | 10:27 AM
cruisemon's Avatar
cruisemon
Default Radar detector installation
I want to install a radar detector at the upper windshield molding on my '98 coupe. Is there a "hot in run" wire in the bundle to the mirror or the lights on the visor? I want to have 12 volts only when the key is in the run position and not 12 volts all the time in case I forget to turn the detector off.
If there is such a wire, what is the color code? Is black a ground, as is common in most circuits? As I recall, C4 had several grounds in the bundle to the mirror and the one chosen had to be a hot in run ground for this type of installation to work. If there are multiple grounds, is there a way to determine which one works other than trial and error?
Charlie Funk
Old Mar 27, 2006 | 10:34 AM
rws.1's Avatar
rws.1
PM CF member Team Speed.
He sell a cord that does exactly that for abour $8. I'm sure he can help you out...
Old Mar 27, 2006 | 10:42 AM
cruisemon's Avatar
cruisemon
Default radar install cable
Will do
Charlie
Old Mar 27, 2006 | 10:52 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
http://mysite.verizon.net/ccm.gerber/quickconnect.htm
Old Mar 27, 2006 | 11:14 AM
cruisemon's Avatar
cruisemon
Default This is great!
Thanks SO much to both of those responding. This is GREAT info! Thanks again.
Charlie
Old Mar 27, 2006 | 11:26 AM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
Just ordered one too, not worth the time to make own cord. $ 14.00
Thanks!
tt
Old Mar 27, 2006 | 11:31 AM
ALLEGRO's Avatar
ALLEGRO
http://www.invisicord.com/docs/quickconnect.pdf
Old Mar 27, 2006 | 11:35 AM
cruisemon's Avatar
cruisemon
Default Invisicord
The link above indicates info for the '99. Wonder if it is safe to assume it applies to the '98 as well.
Charlie
Old Mar 27, 2006 | 12:06 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
Charlie
Should be ,make sure the door is closed and the ignition on , I beleive its the last wire on the right and the second from the left when you look into the plug. I used a phone cord but had to splice into the wires .
To Radar detector installation
