The part is a rod and another plastic piece. If your mirror has a screw hole in the bottom the rod screws right in . If not (and the 03's don't) you super glue the plastic piece in and then screw the rod up into it. I have a Passport and the rod goes through the re-bent bracket and is secured by the nut.
For yours you'll need to figure if your bracket has a place for a small rod to pass through. I'm guessing it won't.
Let me know if you want the manufacturer's email to verify with them.
