Charging system problem - battery or alternator??
Old Mar 27, 2006 | 02:32 PM
Silver Bullet 99's Avatar
Silver Bullet 99
Default Charging system problem - battery or alternator??
How can you tell its time for a new alternator vs replacing the battery? I've had this Vette for about 2 years now so I'm not sure how old the Optima Red Top battery is. I had to jump the car on Saturday morning and I let it run for about 15 minutes. Then later Saturday night I went to take her for a spin and it needed a jump again to crank over. I ran her hard for about 30 minutes and put her away for the night....now its Monday and I just tried to turn her over and it near dead again. The alternator does make a ticking noise but I believe its done that since day one.
What do you guys think? Replace the Red Top or take her to the shop for a new alternator or charging test. I just hate to drop $100+ for a battery only to have to spend who knows what on a new alternator in a weeks time.
Old Mar 27, 2006 | 02:43 PM
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
Autozone will do the test for free in the parking lot. Sounds like a battery to me. If you do replace it, make sure it has a full charge or you will cause alternator (I think the vette is actually a generator) problems the first time you crank it over.
Old Mar 27, 2006 | 02:52 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Sound like the battery to me also..
your red top Optima comes with a 4 year replacement guarantee..as long as you have the receipt.
Old Mar 27, 2006 | 02:57 PM
Silver Bullet 99
I wish I had the receipt - maybe the prev owner was smart enought to sticker it under the battery before the install. I didn't know Optima had a 4 year guar!!
Old Mar 27, 2006 | 03:01 PM
sunnyvette's Avatar
sunnyvette
Sounds like a battery. If it was the alternator, you'd lose power while driving and then your car will shut down while driving
Old Mar 27, 2006 | 03:12 PM
DjCritterus
St. Jude Donor '09
Will you describe the stickers on the top and side of the battery for me?
I am specifically looking for a circular sticker on the side with a letter, dash, and a number.
If you do this, I can tell you where it came from and what month of what year it was bought. Most companies, if they recognize the battery as being their's will exchange/pro-rate it without the original reciept for customer loyalty.
Old Mar 27, 2006 | 08:24 PM
DjCritterus
St. Jude Donor '09
PM sent.
Old Mar 27, 2006 | 10:09 PM
Cart99's Avatar
Cart99
Check your voltmeter with the car running. If your alternator is charging, it should read approx 14.5 volts.
However, based on your symptoms, the alternator has to be working. If it needed a jump start, and the alternator wasn't charging, it probably wouldn't start to begin with -- unless you charged the battery first.
Old Mar 28, 2006 | 10:09 AM
kalister1's Avatar
kalister1
Do you have a volt meter? If so then check battery voltage with the engine off, you should see OVER 12 volts (12.4/5?) Now start the engine and again check battery voltage, you should now see 13.? to 14.4/5/? with the engine running. If you see your charging voltage come up then that would rule out a bad alt.
Old Mar 28, 2006 | 10:54 AM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
I just went through this problem with my car. I'd have to jump it to get it started. I'd drive around for an hour straight, turn it off and then try to start it after a few minutes, and no luck. I took my Optima back to where I bought it (Advance Auto) and asked them to check it. They put it in their machine and said it was a bad battery. I bought it there just about three years ago but didn't have my receipt. Luckily, the guy who sold me the battery remembered my car and said it was within the three year warranty period so I got a new Optima for free. I put it in and now my car fires right up with zero problems.
Old Mar 28, 2006 | 12:18 PM
Silver Bullet 99
Looks like majority rules - bad battery! Thanks all!!!
Old Mar 28, 2006 | 12:32 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Battery is for starting / alternator is for running. Your car RUNS fine. Just need a new battery
Old Mar 28, 2006 | 03:26 PM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
I realize this is all said and done with, but just to satisfy my own curiosity, how come no one suggested simply taking one of the battery terminals loose, while the engine is running?
If the alternator is good, it will keep running. If not, then it will stall out immediately.
Is this not a good idea with modern cars like the vette and all the computerized gadgets, or what?
To Charging system problem - battery or alternator??
