evert once in a while under hard acceleration engine cuts ouy for a split second and then continues on ok, as if it loses ignition or no gas anyone had this problem ? it's a 02
A new Z06 owner in my area reported that his was cutting out under hard acceleration at 155 MPH. Turns out the tires were still slipping and the traction control was causing the miss. Turned off the traction control, and the problem disappeared!
Mine will do this but never at those speeds.
Turn off TC or put on Comp driving.
