Important trunk ?
Old Mar 27, 2006 | 06:22 PM
steve8's Avatar
steve8
Default Important trunk ?
I just got the rear carpet out ready for insulation and see my trunk latch is seriously ^%$&** up. There are four threaded push type bolts that hold the mechanism in place, the part that stays mounted to the car. The two on the drivers side are useless, it looks like the holes are blown out. One on the passenger side looks just about as bad. I'm certainly no expert on body work. My question is, can I fill those holes with some kind of resin and put the pins into the resin/compound, whatever. Or, should I just take it to the dealer and let them fix it. It's a 2004 vert with not even 5k miles on it! Thanks.
Old Mar 27, 2006 | 07:10 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
WOW.....I wonder how there was that much stress placed on the mechanisim to blow out the holes? I'm not an expert either, but I would suggest taking it to a competent body shop. The dealership is simply going to outsource it (I would suspect) to a body shop anyway.
There is probably some resin that you can get, but I would be concerned about whats beind the holes to "hold" the fill.
Other suggestion is to post over in the Car Care Forum. Some real experts over there that you get a good read from. Good luck and let us know what you end up doing.
Old Mar 27, 2006 | 07:15 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
I would also like to know how it happened...I have an '04 Vert that I just started insulating(the trunk area) today and I can't imagine how that happened
Old Mar 27, 2006 | 08:02 PM
tiojames's Avatar
tiojames
Default trunk
You might check an auto parts house. There are fasteners that go in a hole and when tightened expand and hold. You can then unscrew the bolt and install the latch using the bolt that installed the fastener.
Old Mar 27, 2006 | 10:05 PM
steve8's Avatar
steve8
[QUOTE=Yello95][QUOTE=c5BlackBeauty]WOW.....I wonder how there was that much stress placed on the mechanisim to blow out the holes?
I wish I had the answer on how it happened, but unfortunately all I have is the question and the problem.
Old Mar 28, 2006 | 01:37 AM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Your profile says you have an '04. You should be under warranty. Take it to the dealer and let them fix it. Even if they outsource it, it'll be on their dime. Why should you pay for a 2 year old part failure?
Old Mar 28, 2006 | 07:37 AM
steve8's Avatar
steve8
Of course you are right about taking it to the dealer. I just kind of freaked when I saw it. It's just that I have perfect access to it right now, and more importantly I have never had to take it to the dealer for anything so far. I know how careful I have been, especially installing all the insulation, draping the trunk, sills etc. and I hate the idea of some apes working on my car. Oh well, the price of warranty work I guess.
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
I doubt they would fix it - they'll probably blame it on you.
Old Mar 28, 2006 | 08:53 AM
kalister1's Avatar
kalister1
Go to this website http://www.enfasco.com/Frame4.htm
You will see what is called a Rivet Nut. They go into blind holes in sheet metal and then you can thread a bolt into (And out of) them. The video shows a power tool setting the Rivet Nut but you can purchase hand tools that perform just as well.
Old Mar 31, 2006 | 09:21 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Excellent!Thanks...right click/save
To Important trunk ?
