[Z06] Dyno, 481rwhp
Old Mar 27, 2006 | 09:41 PM
Chuck Harmon's Avatar
Chuck Harmon
Default Dyno, 481rwhp
Just back from synergy Motorsports to get my car tuned. I was very impressed with the job Rick did. Thought you might like to see the graph. I also thought many of you might like to see the comparison graph for my much lamented 69 L88 clone. I loved the power of the L88 but I also love a/c, power steering, stereo, etc. I now believe I have almost got my L88 back, at least in spirit.
The Z has an SLP 402 with AFR 225 high compression heads. I am running a 228/230 @ .591 lift on 114 centers, LG long tubes with high flow cats, stock air cleaner assembly and intake.
The L88 was a factory crate motor with all factory internals. i.e L88 cam, forged 12:1 pistons, alum factory heads 2.19/1.88 valves, factory stamped L88 intake and replacement Holley 4 barrel, Hooker side pipes.
Chuck
p.s. I believe I know have as much or more rwhp as the marvelous new ZO6
Old Mar 27, 2006 | 10:38 PM
Kappa's Avatar
Kappa
Very nice numbers especially considering the cam size.
Old Mar 28, 2006 | 12:53 AM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Old Mar 28, 2006 | 01:16 PM
99vettecoupe's Avatar
99vettecoupe
Nice! I have a similar setup. SLP 402 with AFR 225 heads. The difference is that I am running a F.A.S.T. 90mm intake, 90mm TPIS tb, a bigger cam, Kooks 1 7/8" headers, X-pipe, no cats and B&B bullets. Air intake is a massive Haltech.
I am making 517rwhp and 490rwtq. Can't wait to try it out at the strip.
Old Mar 28, 2006 | 01:30 PM
Shark Racer's Avatar
Shark Racer
Absolutely incredible. Too much power for someone like me to handle.
Old Mar 28, 2006 | 03:30 PM
Scott04Z's Avatar
Scott04Z
From: I'm not quite middle aged and I only own one gold chain! San Jose CA
Congrats on the great numbers Chuck! Having had the privilege of riding in both your cars I can say you have a real monster on your hands that compares very favorably with the performance of the 69. I am predicting long black strips of burned rubber in our culdesac and some fun surprises for the unsuspecting C6 Z06s in the area!
I will be available to bail you out any time you need me!
Old Mar 28, 2006 | 03:56 PM
bernrex's Avatar
bernrex
Did you take it to Myron Candell (in Minn.) for the work ?
Old Mar 28, 2006 | 05:44 PM
jhong321's Avatar
jhong321
Hey Chuck
Great Numbers Now we need to get you to a track
Jerome
Old Mar 28, 2006 | 06:08 PM
99vettecoupe
No, John Boos at Boos Performance.
Old Mar 28, 2006 | 09:08 PM
lewishou's Avatar
lewishou
Very nice numbers Chuck. Did Rick do the 402 swap as well?
Lewis
Old Mar 28, 2006 | 09:28 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Congrats to you both on the fine results, and welcome to the 402 club!
Old Mar 28, 2006 | 10:16 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Congrats on the numbers!
Old Mar 28, 2006 | 11:55 PM
Pio's Avatar
Pio
Chuck , what clutch are yoy running?
Old Mar 29, 2006 | 12:41 AM
Chuck Harmon
Pio,
Fidenza alum flywheel with LS7 clutch & pressure plate.
Lewishou,
I would have taken the car to Rick for the engine swap; but because it was on a day that Synergy was closed when I discovered my factory engine basically toasted due to a broken valve spring, I took it to Valaya Racing which was about 20 miles closer. Without raising the rath of others on this forum, can I say that he specializes in Vipers? There were 16 there one day. Even so, he is a great guy and I was very pleased with his work overall, even if there were a few things he wasn't as up on as Rick would have been.
Chuck
Old Mar 29, 2006 | 09:24 AM
99vettecoupe
Pio,
Lewishou,
Chuck
How do you find that clutch? I am running a Spec III and get a bit of chatter so was contemplating this swap.
To Dyno, 481rwhp
