Z06 shifter............................
Old Mar 28, 2006 | 11:20 PM
MedChoice Tony's Avatar
MedChoice Tony
Default Z06 shifter............................
I had put in the z06 shifter and the neutral wasn't there...it was just very loose and would not stay in the middle...Also wouldn't shift into 1st/2nd...it would start out in third...
So....what I didn was keep the base of the stock shifter and put in just the bolt and **** into the old base and it worked fine...
Did I do something wrong for it not to work with the Z06 base..
Thanks,
Tony
Old Mar 29, 2006 | 12:15 AM
Classic-Chevy-Guy's Avatar
Classic-Chevy-Guy
I ran into a similar problem on my buddy's C6 Shifter in his C5. You need to place the car in neutral and install the shifter with the pin in place. This lines up the play in the shifter to the tranny. Or, line up the new shifter and the same bolt position as the old one. There seems to be some play and if the bolts are not put in the same place, you experience just what you did.
My .02
Old Mar 29, 2006 | 06:23 PM
MedChoice Tony
It worked...you the man.......
Old Mar 29, 2006 | 09:17 PM
Classic-Chevy-Guy
Glad I could come to the rescue. Corvette Forum Rocks!!!!!
To Z06 shifter............................
