How do lower the front even more?
Old Mar 30, 2006 | 09:44 PM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Default How do lower the front even more?
Recently lowered the car (front and back) using the stock bolts and standard lowering procedures (did not cut the bushing in the back). I like the new set up but the front could be a touch lower for my liking. Anyway of doing that? (Keep in mind I turned the bolts counter clockwise as much as they would go so no more room in that adjustment)
Any suggestions?
TIA
jdmvette's Avatar
jdmvette
Night Owl for life
cut or remove the bushings.
Old Mar 30, 2006 | 09:56 PM
98NassauBluC5's Avatar
98NassauBluC5
From: I'm a Texan, but I traded the horse for the Vette.
Yea, this is a problem for me too.... I dunno what to do, man.
Old Mar 30, 2006 | 10:00 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Cut the bushing off the bolts, or remove the bolts completely.
Old Mar 30, 2006 | 11:10 PM
DRJJ1's Avatar
DRJJ1
Default you guys r nutzz
Originally Posted by 4GTABODT
Recently lowered the car (front and back) using the stock bolts and standard lowering procedures (did not cut the bushing in the back). I like the new set up but the front could be a touch lowering for my liking. Anyway of doing that? (Keep in mind I turned the counter clockwise as much as they would go so no more room in that adjustment)
Any suggestions?
TIA
did you say lowered? wow,,I am so careful but i keep hearing scraping sounds when I go up driveway ramps I go in on angles down on angles,,but nothing is a great way to go up or down a driveway any way to raise the car in front a bit im going to install the frame guards soon with the roller ball for the front bumper but how can you go lower than stock? thats the question!!!
Old Mar 30, 2006 | 11:25 PM
KMeloney's Avatar
KMeloney
Huh? Maybe it's the lack of punctuation, but... What IS the question?!
If you're wondering how anyone could want to lower his Vette, just check out all of the lowering posts here. LOTS of people lower their Vettes. (Incidentally, the scraping you hear is likely the rubber airdam pieces, and nothing to think twice about.)
To the original poster, yeah, just cut the bushings. Then make sure you drive the car for a week or so -- only then will the car "settle" to its new height.
-Kirk
Old Mar 31, 2006 | 01:12 AM
BrianWe's Avatar
BrianWe
EG, care to chime in?
Old Mar 31, 2006 | 04:21 AM
randy814u's Avatar
randy814u
Low is good.
Old Apr 13, 2006 | 01:33 AM
Miguels's Avatar
Miguels
Can you cut the bushings with the bolts still in? I think I say like three ribs after lowering completely. Can I just cut one rib without removing the bolts off? I don't want to raise the back, but currently I have no rake...I am at 4.5" from and back....I would like to go down about .5 "
Old Apr 13, 2006 | 02:33 AM
Crabr1's Avatar
Crabr1
Default Bolts removed
Heres mine with longer rear bolts and I removed the bolts from the fronts.Get Bilstein Sport shocks and you'll be happy.
Old Apr 13, 2006 | 02:35 AM
randy814u's Avatar
randy814u
Like that hood.
Old Apr 13, 2006 | 03:27 AM
JETZ's Avatar
JETZ
Front bolts removed Mo!
Don't forget the frame savers from A&A.
To How do lower the front even more?
