A/C problems
Old Mar 31, 2006 | 03:06 PM
jbowling's Avatar
jbowling
Default A/C problems
For some reason, the AC in my 2K coupe doesn't want to turn on. I hit the AC button and after a second or so, it just goes out. I can turn the automatic climate control on and it won't blow cold either. I just got this car a month or so ago and haven't yet had a chance to look at it (just figured this out on the way to work). Any ideas? Maybe system needs charged??
Old Mar 31, 2006 | 03:25 PM
rws.1's Avatar
rws.1
when you do that, is the green light flashing? If it is, the first thing to check is the R134A charge level.
Old Apr 3, 2006 | 02:54 PM
jbowling's Avatar
jbowling
Nah, it isn't flashing, it turns on for a second or two and I hear the compressor kick on and after a second or two, the light and the compressor goes back off. I checked the pressure at the low-side valve and it was showing almost 70 psi?!?!? Shouldn't it be closer to 25 or 30? I thought maybe I was checking the wrong place or something, but the guage only fits one way and it was the valve between the compressor and the condensor.
To A/C problems
