I ordered a set of clear corners.....before I go tearing apart the entire front end of the car....anyone done this before and have a somewhat decent procedure for doing it? Thanks guys!!
Haha, I just did this today. Assume you're talking about the front side marker lenses.
It takes awhile but it's not too hard. You just need a 7mm socket. I went from under the car and removed the black plastic guard. Then, I pulled the brake cooling duct down and out of the way a bit. From there, I felt up to the light and there are 3 bolts and 2 bulbs holding it in. Use that same 7mm socket to undo the bolts. Carefully slide the housing out and put the new one in. Put everything back and move on to the other side.
It's not that bad!
cool, thanks man, thats what i figured, but thought id ask before i went tearing everything apart
Yes, and you can use any color bulb, well technically the glass color of the bulb, but the illumination should be amber. But if you think you can get away with other colors such as blue, green, red or purple. Do it at your own risk, I have blue bulbs with white illumination.
