Installing hurst short throw shifter difficult???
Old Apr 1, 2006 | 09:31 AM
Mr.Z-06's Avatar
Mr.Z-06
Default Installing hurst short throw shifter difficult???
Hey all, just wondering how hard it is to install a short throw shifter. Any downside to changing out the stock shifter to the short throw?
Thanks in advance!
Old Apr 1, 2006 | 09:36 AM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
Extremely easy. The shifts are more stiff at first but after a while they become easier. You can change out springs to make it easier or bias to one side or another. Remove the shift stop screws or use loctite. You dont want them to become loose becuse they work into the shifter and prevent you from shifting into gear.
If you dont like it just remove and replace with the stocker....
Directions are provided. Also, you can search for links to people that have posted pictures. I would but i lost all my links when my comp crashed last week.
Old Apr 1, 2006 | 10:47 AM
Alcee1's Avatar
Alcee1
Heres the link I got when I asked the same question.
http://temp.corvetteforum.net/c5/pa...erInstall.shtml
Old Apr 1, 2006 | 10:48 AM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
Yeah, it's a fairly easy install.
Old Apr 1, 2006 | 10:55 AM
TripleBlackxThree's Avatar
TripleBlackxThree
St. Jude Donor '07
As others said... easy to do. With the exception of removeing the 'demon' key. But follow the instructions and it's not bad. Consider doing some of the noise reduction mods for the Hurst while you are doing it. Some have had some rattling noise after install, but there are some good counter measures for this. Hope you enjoy your Hurst as much as I do mine.
Old Apr 1, 2006 | 11:27 AM
Mr.Z-06's Avatar
Mr.Z-06
Default bad link
Thanks for the info - but your link is bad.
Old Apr 1, 2006 | 11:37 AM
TripleBlackxThree
St. Jude Donor '07
30 seconds with search will work wonders.
http://temp.corvetteforum.net/c5/pat...rInstall.shtml
Old Apr 1, 2006 | 01:15 PM
sage666's Avatar
sage666
Demon keys are easy to remove IF you use a paint can lid opener like the free ones at Home Depot or Lowes. You hook the lip on the opener under one side of the demon key and press down slowly.
Old Apr 1, 2006 | 02:33 PM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
Or you can put a flat screw driver under each side. Push each driver down and that baby should slide right out.
Old Apr 1, 2006 | 03:03 PM
Mr.Z-06's Avatar
Mr.Z-06
Default Thanks everyone...
Really appreciate the feedback.
-Mr.Z-06
Old Apr 2, 2006 | 08:43 PM
Alcee1's Avatar
Alcee1
Just completed this install, it took all of 30 minutes. Really easy mod and worth it too.
To Installing hurst short throw shifter difficult???
