need help installing seatback hoops
Old Apr 2, 2006 | 10:54 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default need help installing seatback hoops
My mom bought a set of seatback hoops and my dad an i are wanting to install them today. they did not come with instructions...just a small tub of epoxy.
can anyone tell me how to install these (pics help out alot)...especially when it comes to the carpet.
thanks
Old Apr 2, 2006 | 01:09 PM
tiojames's Avatar
tiojames
Default hoops
Do a search on the forum here. I have seen pics of installs on it. One thing I know is that you are going to need a lot more epoxy than one small tube.
Old Apr 2, 2006 | 01:26 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
The quart size tub is plenty.just take your time marking the carpet for cutting,that is the most difficult part..imho.
Cut the holes small and enlarge as needed,a little at a time.You have several options on where to put the slits...directly behind the seats(4 long ones),back in the rear compatment( 4 small slits,but can be seen from the rear)or between the hoops themselves(2 only,so it fits like a "t-shirt",but you will need some double sided tape or other to keep them from raising up)
As far as the install,just line them up good,protect your interior well,check for interference with the top movement on a vert,and Be ready when you mix the epoxy!
That stuff goes off real quick, don't let it catch you shootin' the breeze,or you could have a mess on your hands!
Good luck, it's not to hard
Old Apr 2, 2006 | 01:44 PM
CUlookin's Avatar
CUlookin
I'll be installing some in the following weeks, If you can wait til then I'll put up a Tech Tip!
To need help installing seatback hoops
