drivers side window is not working thanks stan !!!!!
My drivers side window had stopped working so yesterday my friend took the door panel off tapped the regulator a couple of times and it started back to working. THanks Stan you are the man dont forget your beer is on the way!!!!!! thanks.
Mine does it all the time. I've replaced both window regulators and they still do it from time to time. When they quit working I just hit the door panel hard while pushing the window button. They'll usually work again for a while.
Originally Posted by Wisdom
Corvette C5 Enthusiast
Thanks for the link. Some good info.
Its most likely not the regulator but the door control module. The relay for window up/down is shot. Check in the C5 Tech section and you'll find a fix for just a couple of bucks.
Bob
Bob
Originally Posted by sts57c5
just an update my window stopped working yesterday afternoon. I dorve my car to work parked it went in the building , when i got off work it was not working . The temp yeserday was in the 70s. This morninh when i was leaving the health club at 6am it started back to working again. the temp was in the 40s this morning.
