'low oil'
Old Apr 2, 2006 | 07:37 PM
BigMacNYC's Avatar
BigMacNYC
Default 'low oil'
I got the 'low oil' warning in my 2000 mn6... How much oil should I add? I heard adding too much can be bad so any suggestions?? I understand moble 1 synthetic 5w- 30...
Old Apr 2, 2006 | 07:38 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Add enough to get the dipstick level correct. When an oil change is done on our cars, it typically needs at least 6.5 quarts.
Old Apr 2, 2006 | 07:39 PM
BigMacNYC's Avatar
BigMacNYC
I am getting a level about half way.... that why I am confussed the warning came on...
Old Apr 2, 2006 | 07:40 PM
azmusclecar's Avatar
azmusclecar
I had a 2000 coupe that did the same thing when I got it back from the dealer.........I WENT BY THE DIP STICK ..........and after a few drives it finally went away. I wouldn't go over the full mark unless you race it and then I think it's only 1/2 qt.
Old Apr 2, 2006 | 08:10 PM
Thud's Avatar
Thud
When I leave my vette parked downhill for a couple hours, I'll get an erroneous "low oil" reading the next time it's started. Keep that in mind...
Old Apr 2, 2006 | 08:11 PM
H8THAGM's Avatar
H8THAGM
Default happend to me
The same thing happend to me soon after I bought my 2k coupe. So I went to the dealer got an oil change and told them the problem. They charged me an arm and a leg then told me to reset the gauge, there's no problem. So less than two months later it happened again. Less than 1k miles driven. Instead of going back to the idiots I check the forum and want do you know problem solved. The previous owner did as I did and took to the dealer who only put 5quarts in when according to some of the members our cars can hold up to 7. One guy with two filter says he puts in 9. Needless to say I have not had that warning pop since. Thanks forum!
Old Apr 2, 2006 | 09:50 PM
Oldvetter's Avatar
Oldvetter
The low oil light comes on at 5.5 quarts or a quart low. Make sure you were not parked on an incline.
To 'low oil'
