Power window broke - common problem?
Old Apr 3, 2006 | 01:43 AM
BrianWe's Avatar
BrianWe
Default Power window broke - common problem?
My passeger side power window broke yesterday. Fortunately, it is in the up position. I hear a click when I press the button, but nothing happens. It is a 2004 with 39k so I am out of warranty. Is it just my bad luck with power windows or is this a fairly common problem? I have replaced the drivers side motor 3 times and passenger side once on my wife's 99 Sunfire with 112k on it.
Old Apr 3, 2006 | 04:12 AM
sebringsilver97coupe's Avatar
common issue. might even read other posts about this, there was one yesterday. just whack the door panel while holding the button down and it should work fine again. weird but so are alot of other things that happen.
Old Apr 3, 2006 | 06:29 AM
cuspid's Avatar
cuspid
Mine was replaced at 20,000 miles, maybe it is because it is not used as much.
Old Apr 3, 2006 | 08:53 AM
Tom/99's Avatar
Tom/99
I had the passenger window motor replaced in my 1999 coupe, with about 14,000 miles on it. It seems to be a common problem, due to lack of use.
Old Apr 3, 2006 | 02:28 PM
sts57c5's Avatar
sts57c5
yeap reference my post on power windows.
Old Apr 3, 2006 | 03:05 PM
StoplightWarrior's Avatar
StoplightWarrior
It's funny, cause mine was doing the same thing. I went to GM and complained (my local dealer is a very large GM dealer) and they acted like it was really uncommon and they didnt know what it could be.
Then they told me it wasnt covered under the EXTENDED BUMPER to BUMPER warranty that I purchased!!
When I went to show them the problem, it worked (of course) so they didnt have to hear me bitch for them to fix the problem...
and GM wonders why they're doing so poorly
Old Apr 4, 2006 | 01:00 AM
BrianWe's Avatar
BrianWe
The Fonz trick didn't do anything for me other than maybe make me look stupid if someone happened to notice. Thanks for the tip though.
Old Apr 4, 2006 | 02:10 PM
corvette Mark's Avatar
corvette Mark
This happened to me on the passenger side. I called Gene's Karshop(forum vendor) and he had a used one for a fair price. It really is not that hard to replace the motor assembly yourself. Take the door panel off and it is pretty straight forward. It would be nice to have a buddy help hold the glass. Before you re-install the door panel make sure you test drive the car on the hwy with the windows up and check for wind noise, you my need to adjust the glass and you want to do this before you re-install the door panel. If you get into trouble someone here on the forum will help you out.
Old Apr 4, 2006 | 02:24 PM
RPHCRMZ51's Avatar
RPHCRMZ51
I just take the bottom of the door panel off , reach in with the end of a big screwdriver , bang on the motor while holding the swith down and it will start working again.
Old Apr 4, 2006 | 03:34 PM
Leo3's Avatar
Leo3
Default Passenger side window
Try this thread:
http://forums.corvetteforum.com/show...w&forum_id=103
I hope that this can be helpfull
Good Luck
To Power window broke - common problem?
