Here is a question.....
Old Apr 4, 2006 | 04:04 PM
tknight4305's Avatar
tknight4305
Default Here is a question.....
Would I have to put run flat tires on my C5 coupe? If I don’t and one goes flat will it mess up anything on the car?
Old Apr 4, 2006 | 04:06 PM
KidCid's Avatar
KidCid
CI 7-8 Veteran
You don't "have" to put runflats on your coupe. Many folks here run non-runflats on their cars. Most of them carry a compressor, jack and plug kit in case of emergencies. It all depends on how comfortable you feel driving around without a spare.
Old Apr 4, 2006 | 04:08 PM
07blackcoupe's Avatar
07blackcoupe
From: Lost in the Pine Barrens with only ketchup and relish packs, New Jersey
Not if you stop the car when you get a flat... if you keep on driving- well then I guess you would cause some damage! ha ha
Seriously, plenty of people will tell you that if you put on non run-flat tires, performance will increase dramatically. I use mine as a daily driver and I like the luxury which I have used once so far! If you do go with non run-flats and get a flat, don't use fix-a-flat which I have read will damage the sensor...
Old Apr 4, 2006 | 04:09 PM
tknight4305
Thanks Yall....
Old Apr 4, 2006 | 06:42 PM
jman1's Avatar
jman1
Old Apr 4, 2006 | 08:29 PM
Oldvetter's Avatar
Oldvetter
If you use nonrunflats and get a flat you MAY destroy the tire pressure sensor in that tire. Then again, you may not. With nonrunflats you don't really need your sensors anyway.
Old Apr 4, 2006 | 10:00 PM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
I have Michelins on mine. They ride soooooo much better than run flats. I also have a cell phone and a AAA card.
Old Apr 5, 2006 | 11:43 AM
No, you don't have to use the runflats on the car. I have Michelin Pilot Sports on mine right now. The only drawback is that if you have a flat, obviously you can't just continue to drive the car. I kept the sensors in my wheels so I can tell if any tire starts to go flat, thereby minimizing any damage that may be done. Just carry a compressor, plug kit, small jack and a cell phone and you should be OK.
To Here is a question.....
