This is un-freaking-believable
Old Apr 5, 2006 | 04:59 PM
chad4msu's Avatar
chad4msu
Default This is un-freaking-believable
All I need is a bolt...
You know that bolt that your headlamps hinge on when they flip up and down? Mine worked its way loose. So I've been looking for another one for 3 days now.
GM won't sell you just the bolt. You have to buy the ENTIRE headlamp assembly to get it which costs over $400! I won't do that.
But I'm really getting stressed now because I have a trip planned for the weekend and this whole situation is so STUPID!
Anybody know where I can get the bolt?
Old Apr 5, 2006 | 05:03 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
What size?
Old Apr 5, 2006 | 05:26 PM
Try a hardware store.
Old Apr 5, 2006 | 05:28 PM
chad4msu's Avatar
chad4msu
Sorry I don't have a metric tape measure but:
Length of bolt past the head = about 5/8" or 21/32"
Length of bearing part of bolt = about 9/32"
Width of bearing part of bolt = about 1/4"
Width of threads = about 3/16"
8mm nut
T-20 bolt (star)
Old Apr 5, 2006 | 05:30 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Try lowe's or home depot it can't be that hard to find a bolt size that you need
o2z51's Avatar
o2z51
uhh go to a hardware store
Old Apr 5, 2006 | 05:31 PM
chad4msu's Avatar
chad4msu
Tried that. But they always ask "what's it for?" If I don't tell them, they aren't willing to help me anymore. And if I do tell them, they say "we don't have anything like that."
chuck1026's Avatar
chuck1026
Cruise-In II Veteran
Bring in the one that remains and match it up... use bushing or washer... whatever. You can make it work. Good luck .
Old Apr 5, 2006 | 05:34 PM
chad4msu's Avatar
chad4msu
i'm going to lowes to try to find a temporary fix until I can find the correct bolt, so perhaps I'll still get to go on my trip after all...
But I went to an auto salvage place today and they just laughed at me. Like if I needed something for a '73 pinto, they would be more than willing to help, but say the word "corvette" and you're hilarious for even walking in the front door...
Old Apr 5, 2006 | 05:38 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Unless you get the whole assembly you are gonna have to improvise. I doubt you will find that exact bolt.
Try Lowe's or Home Depot. And don't ask for help. Search thru the bolts and see if you can find something that might work.
Lets see, you need a bolt, maybe a nylon spacer or washer... you get the idea.
Old Apr 5, 2006 | 05:43 PM
Red3644's Avatar
Red3644
Why don't you try an "AUTO PARTS" store....go through the bins at a NAPA. Or a fastener seller. There are at least 4 or 5 nut and bolt suppliers in town here. Hope that helps.
Old Apr 5, 2006 | 05:52 PM
istsme98's Avatar
istsme98
a good old fashioned hardware store would work
Old Apr 5, 2006 | 05:54 PM
Superbock's Avatar
Superbock
The stores may fail you. Look up a machine shop in your area, If the do not have something they will make it for you.
Old Apr 5, 2006 | 05:56 PM
rwsr50's Avatar
rwsr50
Without seeing how that bolt actually works, it looks to me like the shoulder keeps you from overtightening it, and the nylon bushing helps whatever rotates on it rotate.
I don't think the thread has to be the same, as long as you get a new bolt and nut to match it. I'd get a bolt the same diameter and as close as possible to the same length. You can always cut it off if it's too long. I don't think the head style matters, but you'll have to figure that out by where it goes, etc.
Next I'd get a steel or aluminum bushing to fit closely over the bolt. Try to get it the same length as the shoulder on the original, but again, cut as required.
Lastly, get a nylon bushing to fit over the steel/aluminum bushing. It will probably be important that the outer diameter matches the original.
Second thought, if you have the original nylon bushing, just reuse that.
You should be able to find all of the above in a GOOD hardware store. They usually have bins or little divided boxes with all that kind of stuff in that you can search thru.
Good luck!
Old Apr 5, 2006 | 06:06 PM
ankle-biter's Avatar
ankle-biter
From: Lat: 33.301 Long: -111.840 For GPS impaired - Chandler, AZ
Try some of the online Corvette salvage sites. You'd be surprised at what they stock.
Old Apr 5, 2006 | 06:10 PM
dndrsn's Avatar
dndrsn
Where's Waldo?
Old Apr 5, 2006 | 06:12 PM
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
N.A.P.A. sells bolts like that. They may be a little long but that's why grinders were invented.
Worst case scenario, get one that's a little long including the cylindrical portion. A machine shop can put it on a lathe and turn it to the size you need and then thread it with a tap&die set.
It's cheaper than buying from the stealership.
To This is un-freaking-believable
Old Apr 5, 2006 | 06:13 PM
jrose7004's Avatar
jrose7004
Try salvage yards!
Old Apr 5, 2006 | 06:15 PM
chad4msu's Avatar
chad4msu
Yes. This is correct. the shoulder goes through the bracket on the light assembly and the threads go through the bracket on the car. So the shoulder also acts as a spacer so that even if you overtighten the nut, it doesn't affect the bracket's ability to pivot on the nylon bushing.
I'm sure there are lots of temporary solutions at either lowes or the local bolt company. I'm just disappointed in GM's parts department this week.
Thanks for all the suggestions everyone.
Old Apr 5, 2006 | 06:17 PM
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
http://www.mcmaster.com/
