[Z06] Z06 + Blower reliability?
Just make sure you get a good hood (motor city mold!) as you are gonna have to look over the top of it.
Also, if your gonna do anything like this to your motor, do the springs.
Cheap insurance.
After 3400 miles i have not even thrown a code and my set-up has been very reliable. The key is not to get to greedy and i shift when i making between 6 to 8lbs of boost, as this seems to be the consensus where the stock LS6 motor may live a while on boost, assuming good tune, etc. I run ALKY also not to make more power, but only for an extra safety measure, as I would rather run a little rich and lessen my chance for detonation, even if it means i make less power, in case i get a bad tank of 93 octane, etc. Of course, figure on a new clutch also and so far my stock springs have been fine and no reason to swap them out if the motor stays stock like mine, although i am now seriously considering swaping to a dual spring for piece of mind and extra protection of a dual spring in case a spring breaks, now that i have 23K miles on my stock LS6 motor!
Is the motor going to live as long as stock, NO DOUBTFUL, but if you play it smart is should last a long time but never any GUARANTEES and the more you push it the greater the odds for failure!!
HOPE THAT HELPS and i highly recommend the ECS NOVI blower KIT for you running no more than 8 lbs on your stock LS6 motor!!
btw: only problem i am having is I dont think the clutch enjoys that much hp
