Did i break something.
Old Apr 7, 2006 | 12:24 AM
big gil's Avatar
big gil
Default Did i break something.
went out for a run today and when i stopped car and put on emergency brake it sounded like something snapped!, i released brake and reaplied brake and brake seemed to still be working. hope i didn't cause any damage.
Old Apr 7, 2006 | 03:00 AM
MrLeadFoot's Avatar
MrLeadFoot
That's happened to me a couple of times. I think that sound is the cable adjusting itself.
Old Apr 7, 2006 | 06:16 AM
SilverBulletZ06's Avatar
SilverBulletZ06
Had it happen to me too and I think I went white.
Old Apr 7, 2006 | 06:33 AM
Mine used to do the same thing. Took it in to the dealer to have it checked and they ended up replacing the entire parking brake mechanism at the console area. Said something like the gears in there were screwed up. Since then it has worked fine. May not be the same problem, but I had the loud pop.
Old Apr 7, 2006 | 12:25 PM
MrLeadFoot's Avatar
MrLeadFoot
Great, just when we all started thinking this might be normal, YOU chime in with THAT!
Seriously, though, thanks for the heads up, JD. Maybe we should start thinking of taking the console section off and at LEAST looking, before something breaks that we could've prevented.
OK, I vote that the person who started this thread be the first one to look and tell the rest of us what they found, so that we all don't have to do the work.
Old Apr 7, 2006 | 04:05 PM
big gil's Avatar
big gil
thanks guys, i'am gonna pray that the cable was adjusting itself and does not need to be changed, because i have no clue as to fixing that type of problem!
Old Apr 7, 2006 | 04:26 PM
hardtop's Avatar
hardtop
Happened to mine as well. Dirt gets in the gears/grease and needs to be cleaned out. Or, you could take it to the dealer. I'm sure they would be more then happy to replace it for you... just get your check book ready.
To Did i break something.
