Alignment specs needed
Old Apr 7, 2006 | 10:45 AM
ZBrink's Avatar
ZBrink
St. Jude Donor '06
Default Alignment specs needed
I don't understand alignment at all and I just lowered my car. What are the exact specs I should give to the alignment shop? I would like something in between reg C5 and Z06. I really want to give whoever does it exact specs with nothing for the m to play with. This is a 98' if it matters.
Thanks!
Zack
Old Apr 7, 2006 | 10:47 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
It has to do with your wheels and suspension... I use the C5 specs (I'm lowered all the way with stock wheels)
Old Apr 7, 2006 | 10:58 AM
ZBrink's Avatar
ZBrink
St. Jude Donor '06
Yeah but even with C5 specs isn't there room for play? I am use to dealing with incompetant mechanics around here so I would like to give them EXACT specs.
Old Apr 7, 2006 | 11:09 AM
MyVetteDream
They should have the specs in the computer...
And if you don't feel they know how to do it, go to another shop... I wouldn't let them touch my car if I even got a hair of suspicion.
Old Apr 7, 2006 | 11:12 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
When they ask you what car it is, tell them your car is a z06, and those are the spec's you want.
Old Apr 7, 2006 | 11:36 AM
ZBrink's Avatar
ZBrink
St. Jude Donor '06
Even if I tell them Z06 specs though, isn't there still room for play, i.e. +/- this and that? I am really looking for someone to actually type in a good set of specs that is somewhere between reg. C5 and Z06 specs.
Old Apr 7, 2006 | 12:04 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Did 'ya look at the sticky at the top of this page?
http://forums.corvetteforum.com/showthread.php?t=984927
Alignment
Autocross
CAMBER: -2.5° front, -1.5° rear; CASTER: max; TOE: -1/8" toe-out, front; 1/8" toe-in, rear --- Source
C5 Service Manual Alignment --- Source
Front Individual Toe +0.04 degree
Front Sum Toe +0.08 degree
Front Individual Caster +6.9 degree
Front Cross Caster within 0.50 degree
Front Individual Camber -0.20 degree
Front Cross Camber within 0.50 degree
Rear Individual Toe -0.01 degree
Rear Sum Toe -0.02 degree
Rear Individual Camber -0.18 degree
Rear Cross Camber within 0.50 degree
Z06 Service Manual Alignment --- Source
LEFT & RIGHT FRONT:
Camber: Specified Range: -1.2 to -0.2 Optimal: -0.7
Caster: Specified Range: 6.4 to 7.4 Optimal 6.9
Toe: Specified Range: 0.15 to 0.25 Optimal 0.20
FRONT
Cross Camber: Specified Range: -0.5 to 0.5 Optimal: 0.0
Cross Caster: Specified Range: -0.5 to 0.5 Optimal: 0.0
Total Toe: Specified Range: 0.30 to 0.50 Optimal: 0.40
LEFT & RIGHT REAR
Toe: Specified Range: -0.06 to 0.05 Optimal: -0.005
REAR
Total Toe: Specified Range: -0.11 to 0.09 Optimal: -0.01
Thrust Angle: Specified Range: -0.10 to 0.10 Optimal: 0.00
Z06 (missing in '01) Service Manual Alignment - as written by Hib Halverson, but same as above --- Source
Front Individual Toe: +0.04 degree +/- 0.10 degree
Front Sum Toe : +0.08 degree +/- 0.20 degree
Front Individual Caster: +6.9 degree +/- 0.50 degree
Front Cross Caster: within +/- 0.25 degree
Front Individual Camber: -0.70 degree +/-0.50 degree
Front Cross Camber: within +/-0.25 degree
Rear Individual Toe: -0.01 degree +/- 0.10 degree
Rear Sum Toe: -0.02 degree +/- 0.20 degree
Rear Individual Camber: -0.68 degree +/- 0.50 degree
Rear Cross Camber: within +/- 0.50 degree
Old Apr 7, 2006 | 12:45 PM
User 81424's Avatar
User 81424
Here's one that I think is easier to read:
Wheel Alignment Specifications
RPO
Operation
Service Preferred
Tolerance
Front Alignment Specifications
All
+ 0.04
+/- 0.10
All
Front Sum Toe
+ 0.08
+/- 0.20
All
Steering Wheel Angle
0.0
+/- 1.0
FE1 & FE3
+ 7.4
+/- 0.5
FE1 & FE3
Front Cross Caster
Within +/- 0.5
FE1 & FE3
- 0.20
+/- 0.5
FE1 & FE3
Front Cross Camber
Within +/-0.5
FE4 (Z06)
+ 6.9
+/- 0.5
FE4 (Z06)
Front Cross Caster
Within +/- 0.5
FE4 (Z06)
- 0.70
+/- 0.5
FE4 (Z06)
Front Cross Camber
Within +/- 0.5
Rear Alignment Specifications
All
Rear Individual Toe
- 0.01
+/- 0.10
All
Rear Sum Toe
- 0.02
+/- 0.20
All
Rear Thrust Angle
0.0
+/- 0.10
FE1 & FE3
- 0.18
+/- 0.5
FE1 & FE3
Rear Cross Camber
Within +/- 0.5
FE4 (Z06)
- 0.68
+/- 0.5
FE4 (Z06)
Rear Cross Camber
Within +/- 0.5
To Alignment specs needed
