Fog Lights
Old Apr 9, 2006 | 10:01 AM
gtoformula400's Avatar
gtoformula400
Default Fog Lights
Can anyone recommend a replacement for the stock fog lights... Im hoping to do away w/ the yellow factory bulbs with out spending a small fortune. Thanks
-Joe
Old Apr 9, 2006 | 10:25 AM
rws.1's Avatar
rws.1
Yellow stock fog lights?
The stock fog light bulbs are clear GE 899 37 W
They can be replaced with clear Sylvania 885 50 W bulbs for more light.
Old Apr 9, 2006 | 10:51 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Piaa 1100
Old Apr 9, 2006 | 11:45 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Originally Posted by RPOZ4Z
Piaa 1100
That's the best bet.
Old Apr 9, 2006 | 08:10 PM
jdmvette's Avatar
jdmvette
Night Owl for life
PIAAs here!
Old Apr 9, 2006 | 09:19 PM
Alcee1's Avatar
Alcee1
I heard there are HID foglights. I might be interested in those myself.
Old Apr 9, 2006 | 10:59 PM
JETZ's Avatar
JETZ
PIAA 1100X put out more light than stock high beams!
Old Apr 9, 2006 | 11:02 PM
ALLEGRO's Avatar
ALLEGRO
885's are a good start. They offer a moderate increase in light and color without much cost at all. Everything else is $$$$$$$$
Old Apr 9, 2006 | 11:05 PM
JETZ's Avatar
JETZ
Hella
http://www.hella.com/produktion/Hell...o_DE_Xenon.jsp
Old Apr 9, 2006 | 11:52 PM
Get a set of PIAAs.
Old Apr 10, 2006 | 01:03 AM
striper's Avatar
striper
PIAA1100x! These lights are bright enough to drive with your main headlights down, definetely much brighter than the stock low beams. Also make great flash to pass lights, people do notice these lights, unlike the stock fogs. For people with Z06's they are great bolt-in. The factory wiring and relay and fuses are already there from the factory. The kit plus a factory fog light switch are all you need. If you buy from litewarehouse.com you can also get mounts for the lights with free shipping.
Old Apr 10, 2006 | 02:58 AM
Shangreer's Avatar
Shangreer
How hard is it to install these? I have a C5 Vert with factory fog lamps.
Thanks,
Shan
Old Apr 10, 2006 | 03:08 AM
debmwb's Avatar
debmwb
There are also SilverStar bulbs that fit our fog lights....just don't remember the number.
Old Apr 10, 2006 | 04:00 AM
C5 RACNG's Avatar
C5 RACNG
Thanks,
Shan
easy install in the factory brackets, will hook up to the stock switch using the supplied harness
To Fog Lights
