I have a '99 coupe. Never had a wrench put to it. I Apoligise.
No column lock problems. I apoligise.
No problems with Goodyear runflats (2nd set). I apoligise.
No problems with the key FOB. Still on the original. I apoligise.
Never been back to the dealer. I apoligise.
No Bose problems. I apoligise.
No problems or complaints after 63000 miles. I apoligise.
Now apologize for misspelling apologize...
Wow just noticed you have been a member for almost three years and this is only your second post...
almost as good as winning the lotto. Go get some tickets!
uh oh, tomorrow you will go out and the battery will be dead with acid leaking out onto the comp, you will find a few nails in your sidewalls, the steering column will be locked permanently, and oh, forgot to mention, you'll probably have had some A-hole break in a key your car/ steal something... Never brag about something being perfect!!
