[Z06] Ignition wire shielding?
Old Apr 9, 2006 | 09:39 PM
FasterIsBetter's Avatar
FasterIsBetter
Default Ignition wire shielding?
I'm in the process of changing the spark plugs and ignition wires on my '03 Z06. I picked up a set of MSD 8.5 mm wires. Taking out the old wires, I see they have metal shields on them. And the wires seem to run very close to the exhaust manifolds. The MSD's have long wire guards on them, but I'm wondering if I should put on the old shields or some of those high-tech wire covers to insulate.
Any suggestions or opinions?? Thanks.
Old Apr 10, 2006 | 11:28 AM
FasterIsBetter
ttt. Anyone?
Related question -- When running track days, do you keep those plastic covers over the top of the engine on, or take them off to aid cooling? Does it make a difference either way?
Thanks.
Old Apr 10, 2006 | 12:11 PM
DPG's Avatar
DPG
St. Jude Donor '06
when i put new plug wires on, i kept the old metal shields on. Figured it couldnt hurt especially since im running headers. Some guys run without the covers all the time and put them back on when showing off the car at a show or gathering. You can also get those koolsox or whatever they are called. They are only $40 and are cheap protection when compared to buying a new set of plug wires.
Old Apr 10, 2006 | 02:48 PM
Ranger's Avatar
Ranger
Originally Posted by FasterIsBetter
ttt. Anyone?
Thanks.
I keep the beauty covers on the LS6 and LS7. Experimented on the LS6 by removing them and measuring h2o temps at the line. Never found an advantage to pulling them.
But many racers pull them off at the track under the theory that they trap heat. They may have some info I missed.
Ranger
Old Apr 10, 2006 | 04:57 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I run HPDE's where the car gets very hot... I take them off. I assume they allow heat to be disapated more quickly in the pits when I have the hood up and the car is cooling. Also, it's easier to inspect the car over and check for anything amiss.
Old Apr 10, 2006 | 10:14 PM
FasterIsBetter
Thanks guys. Much appreciated.
To Ignition wire shielding?
