I have a 2000 manual vert with the memory, sport seats and telescoping steering wheel options. Last week, when I got back into the car, the memory function had quit working. The drivers seat has moved all of the way back and it will not move forward when I push the memory option or when I use the electric adjustment on the side of the seat. When the seat went back, the steering wheel also retracted and it too will not return to the normal position. I tried pushing the telescoping toggle towards the dash 6-8 times and then held it in the out opsition for 5 - 10 seconds and no luck. All other functions operate as they should.
I have tried disconnecting the battery and reconnected it after an hour, and still can't get no satisfaction...
When I push the memory 1 button, the light flashes several times or stays on for about 15 seconds.
There is no information in the owners manual on correcting this problem.
