Xpipe Or Not??
Old Apr 11, 2006 | 09:35 AM
carpetman2's Avatar
carpetman2
Default Xpipe Or Not??
Getting ready to install some BB bullets on my 01 Z06 with stock motor and wondering if i need the xpipe. I do have burble on deceleration right now but it doesnt bother me to much. What are the benefits of the xpipe? will it help with drone? some opinions would be great.
Old Apr 11, 2006 | 09:59 AM
Postergeist's Avatar
Postergeist
I don't know about the drone, but it's supposed to reduce (not eliminate) popping on deacceleration. That's the only appreciable benefit I've heard with one. Heck, I like the popping... bring it on!
Old Apr 11, 2006 | 10:08 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Why have a performance exhaust, if you don't know it's there.
Old Apr 11, 2006 | 10:10 AM
H8THAGM's Avatar
H8THAGM
Default xpipe
Here we go again!!!!
Old Apr 11, 2006 | 10:16 AM
jackj's Avatar
jackj
I have Corsa Pace car, I put on the X pipe and hated it, it just killed the sound at WOT, my opinion don't waste your $$$,
Old Apr 11, 2006 | 10:28 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
the xpipe serves a more usefully purpose than making sound.It is designed to balance the engine exhaust scavenging equally which helps pull exhaust gases from the engine more efficiently, and in doing this balances the idle and the acceleration smoothness.
Old Apr 11, 2006 | 10:30 AM
jrose7004's Avatar
jrose7004
Yes I think you need a X-Pipe.
Old Apr 11, 2006 | 10:34 AM
ORANGEBROTHERS's Avatar
ORANGEBROTHERS
It helps...
Old Apr 11, 2006 | 11:48 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old Apr 11, 2006 | 12:20 PM
C6NRED's Avatar
C6NRED
Default you will love it!
I don't know how anyone can say that the X "killed" the sound --- unless they really like the loud popping and snapping off throttle on most aftermarket systems. I really did not like that part of my Corsa Indy's.........that and getting rid of the "motorboat" uneven exhaust pulses was worth it to me..........
Old Apr 11, 2006 | 12:33 PM
ORANGEBROTHERS
My Buddy has a 2001 A4 coupe with just Stingers, mine is an 02 A4 with Stingers and X. Even he said my car sounds much better all around and pulls harder.
Old Apr 11, 2006 | 02:11 PM
C6NRED's Avatar
C6NRED
Default to x or not to x
Old Apr 11, 2006 | 03:40 PM
Evil-Twin's Avatar
Evil-Twin
The h pipe is not about sound..............its about idle and smoothness
the x pipe is not about sound................
the xpipe does a better job of allowing the car to run better,,,Idle better and produce better performance.... sound changes are a by product of the whole concept........
Trying to teach automotive technology here is like trying to teach sheep... they all follow the herd, even if the leader is the wolf....
when you think x pipe, you have to think along the same lines as long tube headers vers stock exhaust manifolds... long tubes are tuned to suck the exhaust gases out quickly and effeciently thus causing less crank resisitence.. the xpipe does a similar thing allowing those pulled gasses to exit quickly and evenly through balance after the exhaust manifold...
The same mentality is here in cam selection.. people ask which cam has the coolest sound, the loppiest or the bad assed sound... people care more about how it sounds than how it performs...
bunch a freekin weenies
Old Apr 11, 2006 | 04:08 PM
jedicowboy's Avatar
jedicowboy
...people care more about how it sounds than how it performs...
So by that token aftermarket wheels, upgraded seat covers, cat-back exhaust systems, etc are a waste? That stuff really only looks or sounds better for the most part. Seat covers don't give better performance. Cat-back exhaust systems don't yeild better performance. I know that these companies claim 10hp. That's bunk though. Most aftermarket wheels are heavier than stock. Are you a weenie? Just by looking at your corvette photos you have all of the above and then some.
And a response in 10...9...8....
Old Apr 11, 2006 | 04:34 PM
Evil-Twin's Avatar
Evil-Twin
You aint sucking me in.....
nothing wrong with appearance mods.....
a cam is not a sound device, its a performance device...
an x pipe is a performance device......
when people ask if they need an X pipe, the answer is yes.
while a cam can perform some wonders, a low LSA will produce a loss of manifold vacuum, be a bit harder to idle and tune out,,, but the "Sound will be cool"
BTW I also have some extensive mods to my engine... and they are there for the reason they were designed...
Neeeeeeeeeeeeeeeeeeeener neeeeeeeeeeeeeener
Old Apr 11, 2006 | 04:43 PM
MrLeadFoot's Avatar
MrLeadFoot
Your exercise in control with your response was priceless!
Old Apr 11, 2006 | 04:53 PM
FASST LN's Avatar
FASST LN
What I don't like is the almost metallic rattling/vibration sound I get at certain rpm. I can only hear it when cruising through my parking deck. I had a similar sound on my '98 SS with a cutout until I added FLP LT and Y-pipe.
I wonder if an X-pipe on the Vette would remove this metallic sound?
To Xpipe Or Not??
Old Apr 11, 2006 | 05:02 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
I have the right to laugh. I have been on the bad end of ET's rants before
Old Apr 11, 2006 | 05:51 PM
Evil-Twin's Avatar
Evil-Twin
Originally Posted by doje
:ROFL: I have the right to laugh. I have been on the bad end of ET's rants before
What you dont understand doje, is that my rants are always meant with love,,,,, kinda like tough love.... one of my students here on the forum once referred to it as "acid humor...." Which pretty much sums it all up LOL
With all my Love
XXX OOO
Bill aka ET
Old Apr 11, 2006 | 06:58 PM
I X L R 8's Avatar
I X L R 8
Cat back exhaust systems dont yeild better performance?
Are you seriously trying to say that a less restrictive exhaust system yeilds no benefit to an LS1 engine?
WRONG.
As to the original posters question. ET is correct. Yes you should use an x pipe with your setup.
He may be ornary, and snide at times, but he knows what the hell he's talkin about.
In fact I'd go so far as to say that not many here know as much about the C5 as he.
When the chips are down, Ive seen many go to the go to guy for advice. Not one single time in over 2 years have I seen him give bad advice and/or information.
Dead on the money each and every time.
