C5 Storage Compartments
Old Apr 12, 2006 | 12:00 PM
Tigershark3's Avatar
Tigershark3
Default C5 Storage Compartments
My '99 owners manual states that I've got three storage compartments in the rear. That's true, but as I see it only one is really usable. The passenger side compartment has my CD changer, the middle has what appears to be a woofer in it leaving only the drivers side for any real storage and that's not much. Is this a common problem? Does anyone have ideas on additonal storage?
Thanks in advance.
Old Apr 12, 2006 | 12:04 PM
y2kcorvettebob's Avatar
y2kcorvettebob
Yours must be a modified version. My changer is mounted in the center against the rear wall and my speakers are mounted behind the seats at the base of the B pillars.
Old Apr 12, 2006 | 12:08 PM
rwsr50's Avatar
rwsr50
Mine too.
Old Apr 12, 2006 | 12:14 PM
N0TDADYS_98's Avatar
N0TDADYS_98
mine as well... but I think i'll relocate my cd changer now to the left one I never use.
Old Apr 12, 2006 | 12:21 PM
Tigershark3
I guess someone could have installed some sort of aftermarket sound system. When I put my CLB in a while back I noticed some non-std wiring that was cut and taped. Question: Was a woofer an optional item in that middle compartment? Thanks
Old Apr 12, 2006 | 12:22 PM
DavesC5's Avatar
DavesC5
The same here on my 1999 and now on my 2004.
Old Apr 12, 2006 | 12:24 PM
Freestyler's Avatar
Freestyler
mine too, but when i went hunting for my lock-nut key i found two comparments behind each outermost brake like that were free n clear for bottles of detailer, clothes and what not! score
Old Apr 12, 2006 | 12:40 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
The only thing from GM that comes in the 3 rear compartments is the optional 12CD changer, which is mounted in the middle compartment. There is a space between the driver compartment and the center compartment to put a wheel key.
jeff
Old Apr 12, 2006 | 01:10 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Nope.
Old Apr 12, 2006 | 01:29 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Thanks in advance.
You can put the woofer on the roof (kinda like the "Blues Mobile"), then you'll have the center compartment for storage.
Old Apr 12, 2006 | 01:38 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
Thanks in advance.
A very common thing to do is move the CD changer over from the center. I did this so I could toss in an aftermarket subwoofer. It pretty much gobbles up all of the cargo space in the center. The drivers side holds a few tools, some detail cloths and a tire gauge. That's about it! Additional storage options are few. Do you still have stereo they installed? Does that subwoofer work? If not, pull it out and sell it. You'd be surprised at how much you can pack into that little center compartment.
Old Apr 12, 2006 | 01:45 PM
utah997's Avatar
utah997
Team Owner<br><img src="/forums/images/ranks/11k.gif" border="0">
St. Jude Donor '07 thru '13
I'm in the same boat. My subs are in a custom poured fiberglass box that takes up the entire center compartment. The passenger side has some sore of electric booster for the 1250w amp. That leaves the drivers side. It's full of rags, detailer spray and a small tool kit.
Old Apr 12, 2006 | 01:52 PM
Tigershark3
Nope - the stock stereo was in there when I got it. Not sure if the sub still works but will check tonight. Great advice and feedback from all. Thanks
Old Apr 12, 2006 | 01:57 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
My guess is they took out the amp that powered it along with their head unit. See what kind of box it is, and post it. Also what kind of woofer and its size. If they are decent and in good shape, you'll find a buyer no problem.
Old Apr 12, 2006 | 02:14 PM
toolluster's Avatar
toolluster
Default Storage Compartment Solution
Remove the 12 disc changer & the sub woofers & the amp & thro them away. Then open the windows & listen to the music that the car makes.
Old Apr 12, 2006 | 04:39 PM
Railfan's Avatar
Railfan
jeff
I have never been able to find that space with a key.
Old Apr 12, 2006 | 05:26 PM
The CD changer was an option on the car. As far as the woofer, the prior owner must have added that since it is not standard on the car. Unless you really want to keep the woofer, take it out and then you have that storage space again. Otherwise, not much else you can do other than just carry a box around in the back.
To C5 Storage Compartments
