Steering wheel removal
Old Apr 13, 2006 | 11:41 AM
Mr. Blue's Avatar
Mr. Blue
Default Steering wheel removal
How tough is it to remove the steering wheel? I have a new VE one, so the old one has to come off. I realize that there are precautions that have to be taken, but I'd rather try to do this myself than let a dealership do it. Any advice would be appreciated.
Old Apr 13, 2006 | 11:47 AM
y2kcorvettebob's Avatar
y2kcorvettebob
Just follow the instructions on the VE website to the letter. I did mine according to Kens Instructions and it went as smooth as glass. one thing I would caution you to do is to remove the airbag fuses and absolutly disconect the battery. Generally that is just a CYA move for the accessory manufacturer but in this case it is 100% essential Have fun and dont forget to post a pic of the finished product
Old Apr 13, 2006 | 11:56 AM
Mr. Blue's Avatar
Mr. Blue
The VE site doesn't recommend removing the wheel yourself. That's why I asked. Not that I don't accept what Ken said, but he had legal responsibilities to worry about.
Old Apr 13, 2006 | 12:16 PM
y2kcorvettebob
OK well I guess they pulled em but I know i got them from Him 2 years ago when I bought My wheel. Heres what you do.
1. Disconnect your battery
2. Find the airbag fuse and pull it.
3. remove 2 screws that come in through the back of the wheel.
4. Carefully disconnect and remove the airbag/horn assy. put aside in a safe location
5. loosen and remove the center nut on the wheel.
6. use a "J" hook type puller to remove the wheel(available at Napa or Autozone). Note: this puppy is gonna seem like it just aint going anywhere and than will pop off all of a sudden like.
When installing the new wheel just reverse the process. I believe that the torque is 30 FtLbs but in my humble opinion, Its a steering wheel, It can't be too tight the whole process shouldnt take you more than an hour start to finish, Including the armour all
Have fun bub
Old Apr 13, 2006 | 12:34 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Had my V.E. steering wheel installed at local dealership for $36!..
Old Apr 13, 2006 | 01:25 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
I would definitely follow the CURRENT instructions on the VE website. It's not worth the risk or hassle. Just take it to the dealership and pay them $50 to do it for you.
Old Apr 13, 2006 | 01:42 PM
Mr. Blue's Avatar
Mr. Blue
It's not the $, it's the fear of what they may do to my car. Same reason why I do as much work on the car as I can myself. I figure if the semi-trained monkeys at MY dealership can do it, as long as no special tools or equipment is required, so can I. No insult meant to places that have good careful techs/mechanics.
Old Apr 13, 2006 | 03:08 PM
CUlookin's Avatar
CUlookin
I figure it's an airbag and shouldn't be messed with by me! Ken told me just to take it to the dealer, and that's what I did... It was like $81, which is fine for piece of mind...
Also, the dealer told me that if replaced it, there could be warranty issues with the airbag so whatever, they did it and everything came out fine!
Old Apr 13, 2006 | 05:11 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
Mine cost $40. Watch them while they work on it. It takes less than 30 mins.
Old Apr 13, 2006 | 09:30 PM
Mr. Blue's Avatar
Mr. Blue
Assuming that all you guys went to Chevy dealers to have this done, just the fact that one place charged twice as much as another scares me.
Old Apr 13, 2006 | 09:59 PM
CUlookin's Avatar
CUlookin
Well I don't know the mechanics at our local dealer and that was the standard servicing quote I got from three dealers... I'm sure if you have a friend who is a tech, a nice 12 pack will do!
Old Apr 13, 2006 | 10:02 PM
SteveDoten's Avatar
SteveDoten
i've done a few of these, in addition to pulling the fuse, i disconnect the srs connector under the column before removing the bag and finally disconnecting the actual bag conn., basically in accordance with the GM shop manual, you see it titled as 'disabling zone srs zone xx'
Torx on the bag bolts
Old May 16, 2006 | 02:09 PM
tbyrne's Avatar
tbyrne
From: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
I was talking to a GM Service Mgr today. He said they recommend resetting the computer after doing this. I can't see doing that after just disconnecting the bag.
Old May 16, 2006 | 03:25 PM
Mr. Blue's Avatar
Mr. Blue
Finshed the job yesterday. No big deal, no computer reset required. The hardest part was actually pulling off the wheel, because i had a "generic" whell puller that didn't have the "arms" that you need to use with late model GM steering wheels. I made a pair from some pieces of all-thread and got the wheel to come off with some considerable effort. The new VE wheel looks good - will post pictures tonight.
To Steering wheel removal
