Horn Stopped Working
Old Apr 13, 2006 | 02:09 PM
peteb48's Avatar
peteb48
Default Horn Stopped Working
My c-5 vert horn does not work from the steering wheel or from the fob. I checked the fuse and it looks OK. any suggestions?
Old Apr 13, 2006 | 02:13 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
better hope that it is not the horn switch in the steering wheel because that part is expensive since it incorporated into the airbag setup
Old Apr 13, 2006 | 02:14 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Horn Broke, watch for finger
Old Apr 13, 2006 | 02:27 PM
ryguy84's Avatar
ryguy84
Same thing happened to me, in the engine compartment by the battery theres that fuse box pull the fuse for the horn and clean the prongs. Its worked perfect for me since.
Old Apr 13, 2006 | 02:50 PM
peteb48's Avatar
peteb48
thanks I'll try that.
Old Apr 13, 2006 | 02:54 PM
cenzo's Avatar
cenzo
Default relay
There's a horn relay in the under-hood fuse panel. And there are others of the same type there which you can swap and determine if it's the relay.
Old Apr 13, 2006 | 02:58 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Also - the horns physically reside in the well beneath the passenger headlight. Make sure those connections are clean (free from corrosion) and tight. I believe that they are simple spade lugs. There are two actual horns down in that area.
Old Apr 13, 2006 | 03:24 PM
sebringsilver97coupe's Avatar
which post will you try?
i hope its this one
.Horn Broke, watch for finger
To Horn Stopped Working
