A/C Problem
Old Apr 13, 2006 | 04:10 PM
LMBZ4ME's Avatar
LMBZ4ME
Default A/C Problem
Hi – Here in AZ the weather is starting to heat up, mid 90’s today. I noticed that my a/c is blowing cold air on the passenger side and warm air on the drivers side. Anybody know what causes this and how to fix it? I do have the dual zone climate control. Thanks!
Old Apr 13, 2006 | 04:40 PM
Dragon-Vette's Avatar
Dragon-Vette
Had the same problem with my 98...put about a can of 134a in the system and it is working fine now...hope this helps.
Jack
Old Apr 13, 2006 | 04:45 PM
maxfli's5's Avatar
maxfli's5
add just a little freon
Old Apr 13, 2006 | 04:52 PM
KonaVette's Avatar
KonaVette
St. Jude Donor '03-'04-'05
Jack
I had my Tech do the exact sme thing last Monday and it solved the problem.
Old Apr 13, 2006 | 05:14 PM
Albino's Avatar
Albino
If it wasn't blowing cold air at all, then I would look into adding refer, and also finding out where the leak is,(refrigerant doesn't just get low for no reason) if you are low on refer, it had to escape from somewhere.
I am more interested in the fact you are getting cold air out of one side of your ductwork and not the other. Damper actuation problem maybee?
Let us know the results.
To A/C Problem
