Born on Date
Does anyone know if GY puts a "born on date" buried somewhere in a code on the sidewall? While I doubt if they are the originals (new to me in Dec. '05) it would be nice to know how old they might be....
Thanks in advance....
U.S. DOT Tire Identification Number
This begins with the letters "DOT" and indicates that the tire meets all federal standards. The next two numbers or letters are the plant code where it was manufactured, and the last four numbers represent the week and year the tire was built. For example, the numbers 3197 means the 31st week of 1997. The other numbers are marketing codes used at the manufacturer's discretion. This information is used to contact consumers if a tire defect requires a recall.
That means my tires were manufactured the 49th week of '00 and they have 18K on them. Should I be worried?
Me? 15117905VEHICLE INFORMATION
Merchandising Model : 1YY67 -2001 CORVETTE CONVERTIBLE Warranty Start Date : 01/15/2001
BARS Order Type : 60 - RETAIL - SOLD
Delivering Dealer : MURREY CHEVROLET, INC.
PO BOX 574
PULASKI , TN 38478-0574
(931) 363-3555
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
11/14/2005 126987 3 N3231 - ACTUATOR ASSEMBLY - HEADLAMP - LEFT - REPLACE 15889 miles
10/28/2004 564878 # C2021 - SUNSHADE AND/OR SUPPORT - LEFT - R&R OR REPLACE 10397 miles
10/28/2004 564878 # C2020 - SUNSHADE AND/OR SUPPORT - RIGHT - R&R OR REPLACE 10397 miles
02/03/2003 519293 # N0110 - BATTERY - ONE - REPLACE 9310 miles
01/04/2001 A17905 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1672 kg (3687 lb) Order Number : CXXH6P
Build Date : 01/04/2001 Build Plant : 115Y - BOWLING GREEN
OPTION CODES
AAB - MEMORY PACKAGE AG2 - SIX-WAY POWER PASSENGER SEAT
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT B34 - COLOR-KEYED FRONT FLOOR MATS, CARPETED INSERTS
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE C05 - CONVERTIBLE FOLDING ROOF
DD0 - ELECTROCHROMIC MIRRORS: ISRV & LH OSRV DD8 - OSRV
DL5 - ROADSIDE SERVICE INFORMATION DECAL FE1 - SUSPENSION SYSTEM-SOFT RIDE
FE9 - 50-STATE LOW EMISSION VEHICLE G90 - REAR AXLE-3.15 RATIO
G92 - 3.15 PERFORMANCE AXLE RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
JL4 - ACTIVE HANDLING SYSTEM JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS1 - 5.7L LITER SFI V8 - 350HP
MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NF7 - FEDERAL EMISSION SYSTEM NLEV NK4 - LEATHER WRAPPED STEERING WHEEL
N37 - STEERING COLUMN - POWER TELESCOPING & MANUAL TILT QF5 - POLISHED ALUMINUM WHEEL
SLL - SOLD ORDERS T82 - TWILIGHT SENTINEL
T96 - FOG LAMPS UL0 - AM/FM STEREO CASSETTE RADIO
UV6 - HEAD UP DISPLAY UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U1S - COMPACT 12 DISC CHANGER, REMOTE U52 - ELECTRONIC INSTRUMENTATION
U75 - POWER RADIO ANTENNA VM3 - CONSUMER INFORMATION LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGG - FRONT TIRE-P245/45ZR17 BW SBR
YGH - REAR TIRE-P275/40ZR18 BW SBR 1AZ - SOLD ORDERS PROC OPTION
1SC - CORVETTE CONVERTIBLE PREFERRED EQUIPMENT GROUP 2: * DUAL ZONE AIR CONDITIONING * FOG LAMPS * MEMORY PACKAGE * ADJUSTABLE SPORT BUCKET SEAT * POWER PASSENGER SEAT * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS: ISRV & LH OSRV * HEAD UP DISPLAY * STEERING: POWER TELESCOPING & MANUAL TILT STEERING COLUMN 11U - LT PEWTER METALLIC
67I - LIGHT OAK INTERIOR TRIM 67T - T0P-LIGHT OAK
673 - LT OAK LEATHER TRIM SEATING
That means my tires were manufactured the 49th week of '00 and they have 18K on them. Should I be worried?I wouldn't be...Just check for any sign of dry rot or cracking. My OEM runflats are older than yours and they look new. Good luck.
VEHICLE INFORMATION
Merchandising Model : 1YY07 -2002 CORVETTE COUPE Warranty Start Date : 11/14/2001
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : STAFFORD CHEVROLET INC.
PO BOX 68
DRYDEN , NY 13053-0068
(607) 844-8113
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 04006 ELECTRONIC COLUMN LOCK SYSTEM Closed
CLAIM HISTORY
10/09/2004 068295 # V1145 - 04006 - PERFORM REPROGRAM AND FUNCTIONAL TEST - MANUALS ON 707 miles
06/19/2002 043471 # B2510 - LATCH/LOCATOR ASSEMBLY, ROOF PANEL REAR - RIGHT - R&R OR R 511 miles
06/19/2002 043471 # Z7901 - 1-DAY COURTESY TRANSPORTATION 511 miles
10/22/2001 A11145 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1677 kg (3698 lb) Order Number : DQVJ7X
Build Date : 10/22/2001 Build Plant : 125Y
OPTION CODES
BGR - BOWLING GREEN PLANT B84 - BODY SIDE MOLDINGS
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE C2L - DUAL REMOVABLE ROOF PANELS
DL5 - ROADSIDE SERVICE INFORMATION DECAL D42 - REAR COMPARTMENT LUGGAGE SHADE AND PARCEL NET
FE3 - SPORT SUSPENSION GU6 - REAR AXLE 3.42 RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
MM6 - 6-SPEED MANUAL TRANSMISSION MN6 - 6-SPEED MANUAL TRANSMISSION
NC1 - CALIFORNIA EMISSIONS LEV NG1 - 50-STATE LOW EMISSION VEHICLE
NK4 - LEATHER WRAPPED STEERING WHEEL N37 - STEERING COLUMN - POWER TELESCOPING & MANUAL TILT
QG1 - PAINTED ALUMINUM WHEEL SLM - STOCK ORDERS
T82 - TWILIGHT SENTINEL T96 - FOG LAMPS
UL0 - AM/FM STEREO CASSETTE RADIO UV6 - HEAD UP DISPLAY
UV7 - WINDSHIELD ANTENNA UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
VL7 - NEW YORK - STANDARD 5 MPH BUMPER IMPACT V49 - LICENSE PLATE FRAME
YGH - REAR TIRE-P275/40ZR18 BW SBR Z51 - PERFORMANCE HANDLING PACKAGE
1SC - CORVETTE COUPE PREFERRED EQUIPMENT GROUP 2: * DUAL ZONE AIR CONDITIONING * FOG LAMPS * LUGGAGE SHADE AND PARCEL NET * MEMORY PACKAGE * ADJUSTABLE SPORT BUCKET SEAT * POWER PASSENGER SEAT * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS: ISRV & LH OSRV * HEAD UP DISPLAY * STEERING: POWER TELESCOPING & MANUAL TILT STEERING COLUMN 12U - QUICKSILVER METALLIC
70I - TORCH RED INTERIOR TRIM 703 - TORCH RED LEATHER TRIM SEATING
