clb/gmpp warranty question
Old Apr 14, 2006 | 09:41 AM
sooz's Avatar
sooz
Default clb/gmpp warranty question
Ok, I'm convinced I need a column lock bypass installed. Now my question is, when I do this, will my gmpp warranty be nullified? Is that jacking around with something that shouldn't be jacked with?
I would call my dealer, but remember they are the ones who know nothing about the February recall.
Old Apr 14, 2006 | 09:48 AM
o2z51's Avatar
o2z51
no your warrantu wont be nullified its a factory recall, btw i had the column lock "fix" and yesterday I got the "pull key" now im scared it will get stuck anyway....
Old Apr 14, 2006 | 09:56 AM
roscoe118's Avatar
roscoe118
Sooz,
That's a good question. I have had mine installed for most of the 2+ years that I've owned my car, and had it in for warranty work, three times, without this particular Chevy dealer ever saying a word.
In fact, I got into an argument with the service writer on one of these occasions when I had it in for the rear differential leak, and they insisted on doing the column lock recall. I said thanks, but no thanks, because I have a CLB installed. He said that they had to do it because it was a safety issue. I said I did not want my dash touched. So we arrived at a compromise whereby they re-programmed the computer (to shut off fuel flow if a "lock" occured), but did not touch my dash (which at that time was just to inpect the locking pin).
I suppose that any given Chevy dealer could take issue with the CLB being installed, but that is a risk I am willing to take. If one dealer refuses to do warranty work because of the CLB, then take it to a different dealer. Or, in an emergency (if no other dealer is available) you could always remove it before bringing it in, and then re-install it afterwards, since it is a very simple install.
I'd be interested to know if anyone else on here has had any issues with a dealer not performing warranty work because of a CLB.
Old Apr 14, 2006 | 10:43 AM
Mr. Wonderful's Avatar
Mr. Wonderful
From: Slower than a speeding bullet................ Fort Lauderdale, FL
Spend the $50 and install a CLB so you don't get stranded
To clb/gmpp warranty question
