14.3 battery voltage?
Old Apr 14, 2006 | 11:10 AM
mischievius's Avatar
mischievius
Default 14.3 battery voltage?
a friend of mine mentioned that batterys should not have any more then 13.5 on them or they will boil... what is everyones battery guage at?
Old Apr 14, 2006 | 11:13 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
14.3 is fine and very normal.
Bob
Old Apr 14, 2006 | 11:15 AM
mischievius
ok thanks man =) i guess he was thinking about older battery's or something.
Old Apr 14, 2006 | 11:19 AM
N0TDADYS_98's Avatar
N0TDADYS_98
i'm at 14.3 as well.
Old Apr 14, 2006 | 11:25 AM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Bob
Old Apr 14, 2006 | 11:28 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Bob
chaase's Avatar
chaase
St. Jude Donor '12
Your friend doesn't know much about batteries..On every car I ever owned, the batter would read around 14volts.
Old Apr 14, 2006 | 11:36 AM
Casem1's Avatar
Casem1
14.4 and 13.8 are the most common 'target' voltages for new car batteries. Almost everything digital runs off of 5 volts and will have it's own regulator.
Fuses are in place to limit overloads... Thats right, they have a purpose.
Old Apr 14, 2006 | 11:38 AM
rickko's Avatar
rickko
Also take note that in cases where your car has not been run for a long time upon initial startup and for a short time thereafter your battery will read a much higher voltage as the alternator charges it up. As the battery begins to store the charge the meter will slowly drop to its normal reading.
..rickko..
Old Apr 14, 2006 | 12:12 PM
georgec114's Avatar
georgec114
Fuses are current overload protection devices...Not voltage.
Old Apr 14, 2006 | 12:31 PM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
Find a new friend, preferably one who knows something about cars.
Old Apr 14, 2006 | 01:11 PM
epicshooter's Avatar
epicshooter
14.4 is perfect for the C-5. I am not sure of any car that would have such a low voltage under normal conditions. Usually 14 is the min......
Old Apr 14, 2006 | 01:30 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Me thinks the question vs the posts in this matter differ
IF you are asking the question of voltage shown on the gauge on the dash, I do believe this does not represent the battery voltage per se.
I believe this is the voltage from the alternator.
Either way, you friend needs to find a new hobby
Old Apr 14, 2006 | 02:48 PM
Bingo Fuel's Avatar
Bingo Fuel
Let Me Bignofi That For U
St. Jude Donor '15, '17
I think it's the voltage from the alternator which is limited by the voltage regulator.
I had a 70's boat motor (merc) that had an overcharge problem, probably from the magnets slipping in the magneto. I'd never seen any vehicle peg it's voltage meter into the red before. It fried the brainbox and some other electronics before I noticed it. Fuses didn't help.
Old Apr 14, 2006 | 03:16 PM
vettesmith02's Avatar
vettesmith02
Old Apr 14, 2006 | 03:18 PM
vettesmith02
Seriously, it's fine, it's the resistance of the battery times the current going through it to recharge the battery and as the current drops, the voltage will come down.
It's normal
Old Apr 14, 2006 | 03:56 PM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
fuses limit current not voltage
To 14.3 battery voltage?
Old Apr 14, 2006 | 07:53 PM
GKrenn's Avatar
GKrenn
mine stays around 14.3 with no battery issues
Old Apr 14, 2006 | 08:10 PM
Roadking's Avatar
Roadking
Roadking
CE#1556
Old Apr 14, 2006 | 08:52 PM
mean lx's Avatar
mean lx
12.6 is considered a fully charged battery. 13.5 -14 is the alternator charging the battery or should be. Check your battery voltage once the engine is off. Check it again later in the day or the next morning. It should still read 12.6; if not it isn't holding a charge. To test the alternator, check the voltage on the battery. After you start the engine, the voltage at the battery should increase to 13.5 volts or so....comprende? Heime
