[Z06] changing the shift boot? how hard is it?
Old Apr 14, 2006 | 03:52 PM
02z06tr's Avatar
02z06tr
Default changing the shift boot? how hard is it?
I have mod red interior on my z and I've been looking at the red leather shift boot, I was wondering how the old on is removed replaced?? I would appreciate any advice, thanks!
Old Apr 14, 2006 | 07:00 PM
bandz7's Avatar
bandz7
1. Take the 6-speed pattern off the shifter.
2. Then take two flathead screwdrivers to the demon key (the silver lock) to get it off. (There are plenty of threads on that one) It took two minutes. Cover the demon key with a towel, and then take the two screwdrivers to pry it upwards. You use the towel to protect yourself incase it goes flying.
3. Unscrew your shift ****.
4. Then the shift boot is right there for the taking.
The entire job should take about 5-10 minutes. Good luck.
Old Apr 14, 2006 | 07:06 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi 02z06tr -
I agree with the aboce -
I used a medium vice-grips, locked it onto the square key, and then used a screwdriver pushed through the opening in the vice grips to pry it up and out -
I used a show rag folded up on the edge of the shift know where the fulcrum of the screwdriver was leveraged on the ****.
It popped out pretty easily this way.
THe boot is snapped in with a plastic ring with "fingers' all around it that clip onto the opening in the console.
Just push the boot down, like you are pushing it into the console cavity, and then once it is down and off of the console, bend it carefully and pull it up and out.
Ten minute job depending on how long it takes to get the key out of the shift ****.
best regards -
mqqn
Old Apr 14, 2006 | 07:21 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
This link from Vette Essentials should also help....
http://www.vetteessentials.com/instr...t_install.html
Old Apr 14, 2006 | 07:28 PM
BillW's Avatar
BillW
Not to hijack your thread, but do the after market boots allow for a shorter shifter or an aftermarket shift **** to be used? I guess what I'm trying to ask is the hole in the top of the boot larger and less tight than the stock one? Thanks.
Old Apr 14, 2006 | 09:30 PM
Z06-JIM's Avatar
Z06-JIM
I have the Vette Essentials "Rat" style boot for my B&M Ripper Shifter.
It is a shorter boot made specifically for after market short throw shifters.
Here's the link:http://www.vetteessentials.com/inter...ucts/shift.htm
Old Apr 15, 2006 | 11:02 PM
02z06tr's Avatar
02z06tr
thanks guys, good stuff, I already have replace the shift ****, that was a real PITA! This sounds pretty easy. Thanks again!
Ed
To changing the shift boot? how hard is it?
