[Z06] question on active handling alert
Old Apr 15, 2006 | 11:59 AM
fxdl's Avatar
fxdl
Default question on active handling alert
yesterday my dic started warning me to, ( service active handling ), ( service abs ) ( service traction control )
anyone think this could be a wheel sensor that needs replacing?
pushing the ''button'' doesn't do anything. i just keep getting the warning. may have to visit the local dealer which brings me to my next question. anyone here in the naples, fla. area have any experience with the local chevy dealer? bob taylor chevrolet. may have to take it there.
02 z with about 34000 miles on it. thanks for any info ya'll can give me.
Old Apr 15, 2006 | 12:40 PM
Ranger's Avatar
Ranger
Suggest you (1) check the codes (2) write them down (3) clear them (4) take a short drive (5) recheck and write down any codes that appear, noting H=history and C=current and finally (6) post them.
The fresh codes, if any, will tell a story.
Ranger
Old Apr 15, 2006 | 01:10 PM
fxdl's Avatar
fxdl
thanks ranger. i'll try that. just didn't want to go to the dealer not knowing anything if i could help it.
Old Apr 15, 2006 | 01:24 PM
deicar3's Avatar
deicar3
Default trouble codes
My buddy and I both had the same problem and we took our cars to the dealer. Low or bad battery sent these codes. I know it sounds strange but they said the batteries were on their last leg. The batterries were at 3 and 4 years old...haven't had any problems since.. Hope this helps.....
Old Apr 15, 2006 | 01:27 PM
03 Z-oh-6's Avatar
03 Z-oh-6
It's probably your battery.
Here's what happened to me(posted on another board):
I had the same problem on my 02 Z about a week ago. Came back to my car after shopping, and the car was dead as a doornail, absolutely nothing worked. Triple A came and gave me a jump start. On my way home, the ABS light, then active handling service lights came on. I was like WTF? Then a few minutes later the car starting acting weird and the service engine light came on. I made it home, turned the car off, then back on, but it was dead as a doornail again. I disconnected the battery and took it to sears. They checked it out and told me the battery was no good, it was very weak and there was a bunch of dead cells. Picked up a new battery from Chevy and everything has been just fine.
Old Apr 15, 2006 | 03:04 PM
FourG63 97GST's Avatar
FourG63 97GST
did it just happen out of the blue?
one time messing around I did couple 360s then the same thing happend, but in the morning the messages was gone. and never came back.So I just hooked up the Tech2 and deleted it form the history
Old Apr 15, 2006 | 03:16 PM
fxdl's Avatar
fxdl
thanks guys; hadn't thought about the battery. i haven't had a chance to do anything to it yet. i hope its as simple as the battery. it may be the original battery as its a gm battery so thats probably a very good possibility. will look into it later though and let ya'll know what i find out.
Old Apr 15, 2006 | 03:19 PM
fxdl's Avatar
fxdl
forgot to mention; i did a couple burnouts the night before after disabling the ah tc button but it never did that before so i'm hoping for the battery to be the culprit.
Old Apr 15, 2006 | 03:25 PM
Ranger's Avatar
Ranger
Pull the codes; if its the battery, there will be telltales.
Ranger
Old Apr 15, 2006 | 03:35 PM
e-hodges's Avatar
e-hodges
St. Jude Donor '06-'09
evry once in a while (3 times a year about) out of the blue I'll get the standard warnings. Every time if I shut it down and quickly restart everything is cool for a while. Next time I'd like to test the ABS when it says it needs service.
Old Apr 16, 2006 | 09:45 AM
hermiejr's Avatar
hermiejr
4th Gear
I had the same problem - took it to the dealer and they replaced a control module of some sort. Cost was around $600 but was covered under warranty.
Old Apr 16, 2006 | 10:00 AM
e-hodges's Avatar
e-hodges
no more warrenty so I think I'll live with it uless it becones much more frequent
Old Apr 16, 2006 | 01:35 PM
VetteFish's Avatar
VetteFish
same thing happened to me about a week ago. just let the car idle for a little, turned her off for a few minutes, started her back up and no problems since.
Old Apr 16, 2006 | 11:18 PM
badaz06's Avatar
badaz06
This happened to mine occasionally and then became like every 4 or 5th time I would drive it. there was a loose wire that had been frayed under the rear wheel that was making contact.
Old Apr 17, 2006 | 12:54 AM
Marine's Avatar
Marine
Same warnings for me for the past week ( service active handling ), ( service abs ) ( service traction control).
Tried all the let it rest, reset and drive for a 15 minutes, disconnect battery...etc. I'll replace the battery tomorrow and see what I get then, since it is 3 years old. If no go then I'll start checking grounds and wires. Not looking forward to that.
To question on active handling alert
