Ok, i was drivin my car yesterday and all the sudden my car started acting weird and my computer said lost of power so i pulled over cuz i would push the gas but,it wasnt goin anywhere so i had to have it towed..It will start but, will hardly move and sounds like crap..Do any of you know what could be wrong? I took it in last week to have a intake put on so i dont know if maybe thats the problem or something totally different. Thanks for any info!
Let's start with what trouble codes you find on your DIC.
To start, I would disconnect the battery for an hour or so, then re-connect, and check the codes again. Attempt to clear out as many as you can. Repost the ones that won't clear.
Those four are related to your tire pressure monitor's at the four wheels. Shouldn't have anything to do with the car stalling out.
V0107 - Are you sure this was a V and not a P?
1278 - Traction control system temporarily inhibited by PCM
1160 - Loss of communication with LDCM
0361 - HVAC, Left actuator Feedback short to GND
0367 - HVAC, right actuator Feedback open.
2252 - Key cylinder switch fault.
1064 - RFA (remote function actuation) Loss of Communication with BCM (Body Control Module)
Thanks!
From these codes I would be more after a battery or ground issue than I would anything else. How old is your battery? Did they remove or disconnect the battery to work on the intake? Is this the OEM battery. Is there any evidence of leaking from the terminals?
You should also make sure that the key pellet is clean (the 2252 error) or try your spare key if you have one. Do any of these codes show a C at the end or are they all HC. Reconnect the battery and try to start the car after you clean the key or use the spare key. If you get it started, check the codes again and see if any additional ones come up.
You might take your battery to a parts place and have it tested. Hopefully someone else can chime in here with some other thoughts as well but many of these types of issues can be brought about by a bad battery.
B.T.W., You're profile says it's an '05 Vette yet your photo shows a C5, what year is your car?
Talon, thanks so much and i will do that now! I dont know how old the battery is cuz i jus got the car about 2 months ago..Also, thats a mistake on my behalf cuz my car is an 04...
