Header Question
Old Apr 16, 2006 | 10:31 PM
Dans 98 corvette's Avatar
Dans 98 corvette
Default Header Question
I had a set of lg long tubes installed about a week ago, i just recently saw the check engine light come on, is it because of the header install? thanks
Old Apr 16, 2006 | 10:32 PM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
it could be what codes are you throwing?
Old Apr 17, 2006 | 05:09 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
probably the 02 sensors...common situation.....just have them programmed off
Old Apr 17, 2006 | 05:15 AM
edensknight's Avatar
edensknight
Very common malady and response to an long tube header system install. However, do run a manual diagnostics to obtain any and all trouble codes presenting currently to help narrow down the problem.
Old Apr 17, 2006 | 06:33 AM
EdsC6Z06's Avatar
EdsC6Z06
St. Jude Donor '05-'06-'08-'10
Expect codes, 1133, 1153, possibly 1134 and 1154, there are others, but you can bet it's the O2's throwing codes after the headers. I'm still sorting out my car after a header install. It's very frustrating, but hopefully all worth it. You can have certain codes edited out, but you need the front o2's to work properly. Just had to replace mine. Good luck.
Old Apr 17, 2006 | 10:08 PM
Dans 98 corvette
okay thanks for the info
To Header Question
