[Z06] Steering/alignment question...my first z06
Given your car only has 6400 miles on it, the alignment is probably okay, but, having it checked certainly wouldn't help. Here are the alignment specs:
Z06 Specs:
Front Individual Toe: +0.04 degree +/- 0.10 degree
Front Sum Toe: +0.08 degree +/- 0.20 degree
Front Individual Caster: +6.9 degree +/- 0.50 degree
Front Cross Caster: within +/- 0.25 degree
Front Individual Camber: -0.70 degree +/-0.50 degree
Front Cross Camber: within +/-0.25 degree
Rear Individual Toe: -0.01 degree +/- 0.10 degree
Rear Sum Toe: -0.02 degree +/- 0.20 degree
Rear Individual Camber: -0.68 degree +/- 0.50 degree
Rear Cross Camber: within +/- 0.50 degree
Please note the large tolerances. For example, the front camber is -0.7 nominally, but is within spec from -0.2 to -1.2 as long as cross camber is within 0.25. I suggest being specific and not asking for something like the "stock alignment" but rather "I want front camber -0.7 degrees" which any good aligment shop should be able to hit within a tenth of a degree.
Enjoy the new ride.
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
