Crazy Window Control
Old Apr 17, 2006 | 06:08 PM
RJS91RGTP's Avatar
RJS91RGTP
Default Crazy Window Control
Hello folks, I need a little input. I own a 2002 coupe with 13,000 on the clock. The last few days my drivers side window control will not work after starting the car. If I open the door and shut, it might work and if I restart the car it might work. What controls the window system, something in the door when it is closed or in the shift know when you move out of park? Is there some connection that I can check or is it just the window control failing? Any help or insight would be appreciated. Thanks
RJ
Suburban Chicago
